Drag Racing Tech
How low to run et streets?
Old Feb 28, 2003 | 08:15 PM
White98Z's Avatar
Default How low to run et streets?
I will be using ET streets in stock 95 ta rims what is the lowest psi you all would run they are not screwed or tubed.
Old Feb 28, 2003 | 09:58 PM
98TAauto's Avatar
Default Re: How low to run et streets?
i just did a search because i trying to find the best PSI for street driving.. someone told me they run 27-30 for long trips?
but for lowest from what I just saw anything below 15psi is very unstable up top end. Some guys are running 18-25psi in them on the tracks and hooking fine. Im just gonna start at 19-20 and go from there with mine. Im definitly not going below 16 or 17 <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Feb 28, 2003 | 10:10 PM
blaSSt's Avatar
I've made a few passes at 15 psi with no problem. I did make a pass at 13 psi last Sunday again with no problem. I am running tubes.
Old Mar 1, 2003 | 06:49 AM
chevyguy3's Avatar
back when i ran 26x11.5 ET streets on stock 16" wheels i had my best luck at 12psi warm (no tubes). hooked the best down there, and below that things started to get a little suirrley up high. this was on a stick car FWIW, i dont think you will need to go that low on a non t-brake auto to get it to hook up
<small>[ March 01, 2003, 06:51 AM: Message edited by: chevyguy3 ]</small>
Old Mar 2, 2003 | 12:51 AM
Silvr98z28's Avatar
On a good hookin track mine ran best at 20-22lbs. Run as much as you can and still hook. You will need to get em hot. Best on ET Streets was 11.30 with a 1.51 at 119. 3450lbs Race weight.
Old Mar 2, 2003 | 03:33 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
In my experience, the tires have grown 2psi after I have finished a run.
12-14psi cold really felt crappy for the last 1/8th of the track.
I like 15-17psi cold. I wonder how much the tires grow from the burnout, that's probably where most of the growth is from?
If you can run them 20psi cold the car will track like a Cadillac.
Old Mar 2, 2003 | 05:54 PM
Kenny H's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Pro Stock John:
<strong>
</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">You got that right! I have had mine down to 12-14 psi for 2 runs and both times I got out of it because I couldn't deal with the way the car felt. This was with skinnies up front and no sway bar as well....
Old Mar 2, 2003 | 05:58 PM
JS's Avatar
JS
Not if u run a tube <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
I run my boots at 12lbs cold,Car flat out HOOOOKS!!!
JS
