Drag Racing Tech
Help with battery kill switch
Old Mar 5, 2003 | 08:00 PM
Gimp98TNT's Avatar
Default Help with battery kill switch
Here's the situation. I moved my battery to the trunk using a moroso box, and flaming river's big switch. I got everything hooked up and working but i hit the switch and the car dosen't die. I hooked up the positive cable to it.
What else could i hook up to make it work? altenator, fuel pump, igntion?
TIA
Jim
Old Mar 5, 2003 | 08:03 PM
Slow 346's Avatar
Default Re: Help with battery kill switch
Your car is running off the alt. You need to run a wire from the switch and splice into the Bat off the alt. to kill it.
Old Mar 5, 2003 | 08:06 PM
Gimp98TNT's Avatar
I know it running off the alt. but it would OK to run the wire all the way back there and back up front. I wouldn't have any charging problems would I?
Old Mar 6, 2003 | 09:54 AM
Reckless's Avatar
Super Moderator
So you are supposed to run the + to the alternator, and then back to the switch, and then forward to the fuse box?
I have never "tested" mine, but would assume I have the same issue <img border="0" title="" alt="[Frown]" src="gr_sad.gif" />
Old Mar 6, 2003 | 10:50 AM
TApimp's Avatar
http://www.painlesswiring.com/catlarge/50105.jpg
painless part # 50105,
that is what u need, we used it on our shop car and it works great
Old Mar 6, 2003 | 11:55 AM
Bad Habit Bird's Avatar
I am in the same situation as Gimp <img border="0" title="" alt="[Frown]" src="gr_sad.gif" />
Old Mar 6, 2003 | 06:12 PM
Gimp98TNT's Avatar
It looks like the painless shutdown relay will work, but they want 70 bucks for it. I would really like to find a cheaper way. I'm way over budget on this little project as it is. I think i'll just try wiring the alt into the switch. I'll problably end up frying the alt or something else and end up costing me more money anyway. <img border="0" title="" alt="[Frown]" src="gr_sad.gif" />
BTW on my racetronix fuel pump there is a seperate wire for power on the harness tried wiring that into the switch. No dice stayed running. <img border="0" alt="[shoot]" title="" src="graemlins/gr_guns.gif" />
Old Mar 8, 2003 | 12:05 AM
Tom the roofer's Avatar
<img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> This may help you <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Tom <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
<small>[ March 07, 2003, 12:07 PM: Message edited by: Tom the roofer ]</small>
