Drag Racing Tech
11's cam only?
Old Sep 8, 2004 | 04:27 PM
slik98z's Avatar
Default 11's cam only?
I've been practicing my techniques to get my 60ft times down. My goal is decent 12's with my 224/228 cam and simple bolt ons. but with the cooler air and decent tracks around im wondering what it takes to get into the high 11's with cam only or if its even possible, no better yet if its probable.
i have an m6 and ill be running kdws tires mostly cause my car is my daily driver as well.
opinions? ideas? coudln't find anything from a search about this so i figured id ask.
Thanks
Travis
Old Sep 8, 2004 | 05:28 PM
jdustu's Avatar
Thanks
Travis
this might help:
https://ls1tech.com/forums/drag-racing-results/213083-who-has-hit-11s-stock-internals-no-power-adder.html
Old Sep 8, 2004 | 07:06 PM
SilverGhost's Avatar
Motorboater
wrong forum. moving to tech.
Old Sep 8, 2004 | 11:29 PM
jerflash's Avatar
hey man get some 16 inch rims to put some nittos on while your at it man
if i can get my 6 speed 2002 ws6 to put down a
12.38 @ 112 with a 1.84 60ft with only a lid, catback, and nitto i think you can run 11s with a cam and simple bolt ons
Old Sep 8, 2004 | 11:36 PM
SMOKIN01TA's Avatar
https://ls1tech.com/forums/drag-racing-results/187330-fastest-cam-only-cars-list.html
here ya go, this it the tread i had going a while back, this is the fastest cam cars on the board.
also look in my sig, im cam only, so yea,very possible.
Old Sep 9, 2004 | 02:46 AM
dug's Avatar
dug
I ran the time in the sig with 245 50 16 sumitono tires. Im shooting for 11s on regular radials. I still have some bolt ons, weight reduction and tuning to do. This was with the stock rev limiter as well. I also need a clutch, the orginal clutch with 82k miles is starting to slip.
There has been a few people who have gotten into 11s cam only on regular radials with a m6. It depends on track prep. On some tracks the tires go up in smoke shifting into 2nd. It was weird. Id get out of the hole ok but when Id shift into 2nd thered be no traction.
Old Sep 9, 2004 | 10:31 AM
CamaroCain's Avatar
If I were you I would buy a cheap set of 16" stocker wheels and put some ET Streets on them and change them at the track of you could put on some BFG or Nitto DR's and change before you go to the track. I'm guessing with bolt-ons and that cam you are around 365-385rwhp at least, and I don't think the radials can handle that. I am assuming you are still on the stock 10-bolt too?? Just some things to think about.
Old Sep 9, 2004 | 12:36 PM
Fireball's Avatar
didya get those springs ok?
Old Sep 10, 2004 | 12:16 PM
Damage Inc.'s Avatar
Sweet Cheeks
11s on a just a cam? Hell, I'm shooting for 10s! Ha. Elevens are no problem with suspension and a lil' weight reduction. Good luck.
Old Sep 10, 2004 | 05:04 PM
SMOKIN01TA's Avatar
Originally Posted by Dear John
Hell, I'm shooting for 10s! .
ill second that
Old Sep 10, 2004 | 05:20 PM
ONGRNGO's Avatar
I am shooting for high 11s with stock internals almost there so a cam only car should be no problem. I am at 12.32 at 112 mods in sig and a 3450 race weight.
Old Sep 10, 2004 | 05:46 PM
jerflash's Avatar
yo man i wish i would have put some headers and a pulley on my car before i riped into the motor i would have gone 11.90s stock internals that would have been fun
smokin that t-rex worked well for you
Old Sep 25, 2004 | 02:08 AM
2MuchRiceMakesMeSick's Avatar
Im right along the side of you
Old Sep 25, 2004 | 12:44 PM
Torkman15's Avatar
10 Second Moderator
Wow all your times mirror my times cept MPH 111.38 with basicaly same stuff and I want 11.99 before getting into the motor. also my 2000 SS is at 3345 with me in it. I love to see jaws drop when I run a 12.30 with a stock LS1.
