dragging Z for 1st time ever, help
A friend had a computer program that says that the shift points should be consistently around 5900 RPM, The max RPM is 6000 however right. Is this where the rev limiter is set to.
It is my understanding that I should finish in 4th as well. Any thoughts.
Should I bring the RPMs up to like 1800 and then dump the clutch on the green light. I haven't driven my car all winter and I forget where the GSC tires will break loose. I need help from experienced Z28/SS racers. Thanks!
Other racing techniques will also be happily accepted (like how to stage best). He has the advantage of familiarity with the mustang as it is his daily driver, but I have only driven the car about 1000 miles last year before parking it. I don't have traction control.
It is now for honor... Help me use the force.
Before you race, watch other cars! Look for where they stage and also look for where the finish line is. Slowly roll up when staging. I come to a stop when the first yellow lights up and then creep forward to light the second light. Go on the third yellow if running a standard .500 tree.
And most of all have fun!
Right before the light turns green should the clutch petal be in to the point just before it grabs to reduce the throw of the clutch and reaction time.
<strong> how about fuel additives to boost the octane. I believe the tank should be 1/4 full of premium 93 octane but not sure about octane booster. Would you guys call doing this fair? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">There a waste of $$.
