Got in a few passes last night...
The DA calculates to ~780ft. last night. I haven't really made any changes to the car since last year except fixing a few things here and there. I do still have an oil leak from a crack in the back of the block, but I managed to rig up a "diaper" to keep the oil from dripping. I just have to keep a check on the oil level, and change out the diaper every few passes.
Due to the crowds last night, I only got in three passes. The car wouldn't hook on t-brake launches, as my 60' times were 1.40 on both t-brake launches. I did one footbrake pass, and did manage a 1.38 60', which resulted in a 10.14 @ 131mph pass. Not too bad for a car with a cracked engine block and running through mufflers. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
I'm hopeful that ARE will finish up my new block shortly, so I can get the car to what I consider 100%, but in the meantime I think I can keep on racing it if I keep an eye on things. I'll be at SLP Day in Orlando this weekend, and then the ET bracket points series racing starts up (at Gainesville) the following weekend.
Hopefully I can poke around with the suspension some more and get things right. I can put everything back the way I had it, but I'm trying to greatly reduce the wheelstands this year...
Derek
Tony
I hope to make some 1/8 mile passes tonight with the New Hot Rod. <img border="0" alt="[evil]" title="" src="graemlins/gr_devil.gif" />
Good luck to ya. <img border="0" alt="[angel]" title="" src="graemlins/gr_angel.gif" />
Coach
A 1.38 off the footbrake is pretty darn awesome.
It will be intersesting once you put in a fixed block to see if your bigger valves will help at the track since that would be the only other change right?
<strong> George, since the motor is going to be replaced, why not bolt on a 200 shot for ***** and giggles <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I'm only replacing the block itself... Beside that fact, my car would never finish the 1/4 mile with any N2O on it, since I'm going through the traps at ~7400rpm as it is now... <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
PSJ, yes, the only real change was the switch to larger intake valves. The car has definately picked up a little compared to runs in similar weather last year... I can't expect it to run the same numbers at 780ft. DA as it did in December (~-1500DA). I think high 10.0's will be the norm once I get the suspension adjusted right.
<strong>I think high 10.0's will be the norm once I get the suspension adjusted right. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">George, I think you mean low 10's/high 9's right? That is awesome.
<small>[ March 28, 2003, 04:56 PM: Message edited by: LIL SS ]</small>
I live by the hundreth of a second. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
For that tenth of a second or less, he's free....nothing else matters
<img border="0" title="" alt="[Razz]" src="gr_images/icons/tongue.gif" />
Josh
