Transbrake users do you shallow stage?
I do my burnout and I pull up the to lights until the 1st set of bulbs light up. When the 1st 2 bulbs light up then I press the transbrake button and take my foot off the brake and the car rolls forward slighty enough and lights the 2nd set of bulbs. At that point I'm fully on the transbrake ready to go.
David
I always shallow stage, but that's more for looking towards the result of consistant lights. Shallow also helps a little to have a running start before you trip the beams and will net a slight gain on ET. Never tried getting into the t-brake while loading the car up. To me it always seemed easier to dial the suspension when the car is neutral since that takes out any potential variances.
Eric
Andy
do you stage, then apply trans brake, wait until the second yellow and go WOT (I assume you can only rev as high as your stall will let you), then on the last yellow release the transbrake and off ya go???
Make sure your in 1st gear
Hold down the button (whereever you have it)
Floor the gas pedal
Let go of the button when you want and get ready to shift, especially if you are using street tires
I tend to shallow stage anyway but the car does roll forward about an inch when I let off the brake.
Put the car back in first gear( arm your nitrous if using any)
creep foward until the first yellow comes on.(purge if spraying)
GO SLOW WHILE CREEPING INTO THE FIRST YELLOW.
creep foward a little until the second yellow comes on,stop, apply the transbrake.
Sportsman tree- give it some gas 2-3k, when the tree starts coming down(when you see the 1st yellow) go WOT, release on the last yellow.
Pro tree-go WOT ,release as soon as you see ANY yellow.
Shallow staging is always better for ET/MPH.
If your reactions are bad on a .400 protree,you might wanna deepstage.
Ken
