Any tricks to pulling the dash and air bag?
i will also be pulling the heater core and fabing up some kinda plate to fill the hole or find the place that sells them already made for our cars.all suggestions are appreciated.
also check me on these weights.
posi to spool(not by choice
) 15lbsheater core, blower and stuff-about 30
passenger air bag-about 13
stock carpet- around 30-40
stock bat(40) to dyna bat (13)so 27lbs
im hoping that combined with me driving the pis out if will get a 10.99
thanks.
Rodney
Drop the steering column and pull the steering wheel. That'll make things MUCH easier. But someone needs to tell me how to get the damn horn thingy back in there to stay.
Billingsley sells a NICE blockoff plate, plus another plate that can hold 2 gauges that takes the place of the A/C controls. I have them both.
I'm not 100% back together after yanking my A/C and airbags, but I'm getting close.
Oh yeah, if you get REAL aggressive, you can pull / cut out the huge rubber mat that goes all along the firewall. That's probably a good 15 lbs right there. The driver's side of that thing takes some cutting on it to get out.
Also, there's dynamat up under the windshield, when you pull the flight deck plastic. It's at least 5 lbs of dynamat, scrapes off easily with a putty knife. It's also in the trunk well.
Have at it, Rodney. Join the club.
oh well, haha. but after i disconected the 150+ conections, cut the 20 or so tie straps and poped out the 50+ pop in plastic conectors and disassembles basically the entire car i have it out. i kinda like the extra leg room, maby ill leave it out and just mount the gauge cluster on a bracket.
now the fun part, getting the heater core and all that crap out.
but thats for tomorrow after work, i had enough for tonight.
i think i did pretty good for 4hrs of work and my first time doing this.all i can say is that it better go mid 10's after all this crap
After about an hour of pulling nuts and bolts and the heater box still woudln't budge I thought to myself...."When the HELL am I going to put this back in?" NEVER! I put that plastic box in a hurt lock and ripped the Son Bitch out of there.
Made it a lot easier to see all the bolts that you NEVER could have gotten out of there without pulling the motor.
If you plan on cutting out the rubber piece on the firewall, there is one annoying bolt that sits dead center behind the motor that runs through a grommet. You could leave it in there and cut around the grommet, but it bugged the crap out of me. It does take a little work to cut around the pedal mounts on the driver's side.
Good Luck
Ross
I'm dropping the car off at GM next week because I can't take it anymore. Any waigers on how much they'll rip me off? HA! Good luck.
Clint
You most likely blew a fuse or caught a wire when putting the dash back in, i dont believe the BCM has anything to do with the radio or power windows in the f-body.
Clint
Clint
Thanks for the tip. I'll look in to getting a new part.-Andrew
time to fight the firewall bolts
also removed the visors, did some wiring modifications and few other things like the matting on the firewall.
btw, i kinda like the hole where the heater core was, im thinking about just putting a lil door in there. changing number 8 would be a breeze. may just have to put one on the other side also.
yea, the hole is nice, i can change out #8 with a 2ft extension now, now its time to put the dash back in.
got to have it back together for next saturday.
andrew, i saw the hvac plate you were talking about but never saw the gague plate. im going to make my own plate for both, im sure i can do it for less that 60bucks. out of a piece of alluminum
