Drag Racing Tech
Need to get back in the game, what to do next?
Old Sep 26, 2004 | 07:00 PM
Dragaholic's Avatar
9 Second Club NA
Default Need to get back in the game, what to do next?
Ok...I really need to get back in the game with my car. I feel like I havent done anything to it in such a long time even though I just installed a brand new Strange 12 bolt and Wolfe roll bar this week. Its always down waiting on parts to arrive to be installed. Within the last year, the car spent more time in the garage than on the street or strip. Im shooting for 10s w/stock heads/bottom end naturally aspirated and I havent added any go fast parts in who knows how long. The last go fast part was a Meziere electric water pump, which I doubt I picked up very much if any. Anyhow, here is a list of most of the things that Ive done to the car, I wanted to see what I could do next. Thanks.
Fast Toys ram air kit
K&N air filter
Texas Speed & Performance air lid
Granatelli MAF
SLP high flow bellow
Bauer Racing ported & polished throttle body
LS6 intake manifold
NGK TR-55s
Holley 9mm wires
Kooks 1 3/4" long tube headers
Custom 3" true duals w/Dynomax bullets dumped
ASP underdrive crank pulley
MTI C2 cam (224/.581/112) plan on changing cams, but dont know which one
Manley valvetrain kit
AMW oil catch can
Billingsley ABS delete
Century 200-4R w/all options
Yank SS4000 soon to swap over to a PT4400
TCI flexplate
Hal shocks in a 4 corners w/R series in front
Spohn-LCAs, PHB, TA, SFCs, & 25mm rear sway bar all in chromoly
BMR-K-member, upper & lower a-arms, & relocation brackets
Airlift airbag
Prothane motor mounts
Energy Suspension tranmission mount
Denny's nitrous ready driveshaft
Strange 12 bolt w/4.10
Bogarts-15x10/ET Drags 15x4/165R
Wolfe chromoly 6 point weld-in roll bar
Weight reduction
Those are the mods that I can think of, but I know that Im probably leaving a lot out. But that should give you a rough idea on what I have and what I could do next. Let me know because my quest for 10s with stock heads and bottom end continues. Thanks.
Old Sep 26, 2004 | 07:05 PM
ss rally red's Avatar
What are you running now? Anyhow sounds like a dose of spray would get you there.
Old Sep 26, 2004 | 07:15 PM
Dragaholic's Avatar
9 Second Club NA
I havent had the car to the strip since May and many mods ago, so I dont have any recent times. My best was an 11.48 at 116 mph with a 1.62 60ft. I want to reach this goal without nitrous or forced induction. (naturally aspirated)
Old Sep 26, 2004 | 08:05 PM
Coach 02 A3 Z/28's Avatar
"The Drag Racing Director"
Take that sum-biscuit-eater to the track already!!!!!!!!!!!!!!!!!!!!!!!!!!
Coach
Old Sep 26, 2004 | 08:15 PM
SMOKIN01TA's Avatar
got a few good ones for ya,
90mm fast intake
tpis tb for intake
and my cam i promise that cam goes 10's, come to thunder ill show ya.
Old Sep 26, 2004 | 08:39 PM
LawmanSS's Avatar
I feel your pain...I'm in the same boat!
Old Sep 26, 2004 | 09:00 PM
cyphur's Avatar
You're gonna need a bigger cam then that my friend. Also start researching the wonderful world of weight reduction!! Turn that bitch into a stripper. Most cars that go tens cam only are weighing in around ~3200-3300lbs. Whats your pig at?
Old Sep 26, 2004 | 09:06 PM
Dragaholic's Avatar
9 Second Club NA
Coach: I dont think the car has 10s in it, but I wanna have the best chance in doing so when I go back. In my opinion, Ill probably see 11.3s with the way it sits, hopefully 11.2s. I definately need to upgrade torque converters and I plan on going with a Yank PT4400. Other than that, a different cam which I dont know what to go with. From what Ive seen, the T-Rex and G5-X2 seem to be the top 2 cams. Other than those 2 mods, I need more suggestions.
SMOKIN01TA: I thought about changing the intake, but I dont know if I should spend the money for the FAST products, do the LS2 intake, or wait for the LS7 to come out. On the cam, the T-Rex is one of my choices, but havent made a final decision yet.
Old Sep 26, 2004 | 09:10 PM
Dragaholic's Avatar
9 Second Club NA
cyphur_traq: I know that a bigger cam is going needed. On weight, not sure where I stand, but I hope to be in the 3200 range. When I visit the track again, Ill be sure to weigh it. Ive removed quite a few things, not too much, but I dont want it to be a stripper.
Old Sep 26, 2004 | 09:32 PM
GeorgeC's Avatar
I went 10.80's back in 2000 with a tiny (by today's standards) 220/224 .532/.535 114lsa Comp Cam. I honestly don't think you'll see tons of difference from a cam swap.
Concentrate on making all of the parts work perfectly together, not just trying to figure out what new doo-dad to bolt on to the car next. What kind of tuning has been done to the car?
Old Sep 27, 2004 | 09:49 AM
Dragaholic's Avatar
9 Second Club NA
GeorgeC: What was your setup back when you ran the 10.80s? Was that cam only, naturally aspirated, stock heads, stock bottom end, LS1 346? How do you make all the parts work together? The car had its last tune back in April of '03 by Jason at MTI. Wouldnt a bigger cam give me a better chance at a 10 sec. timeslip?
Old Sep 28, 2004 | 06:38 AM
GeorgeC's Avatar
I'm not saying that a bigger/better cam wouldn't help with your goals, just that it's probably not the one piece of "magic" you're looking for.
My old setup then was a stock crank/stock rods 347 (different pistons), GTP 2.02/1.60 heads, Comp 220/224 cam, Dynatech headers, LS6 intake, 4.33 gears, TH350 tranny w/JW 4500 converter, and most of the bolt on goodies... I used to swap parts all the time (which gets old, and expensive), but it did allow me to do alot of experimenting with different combos in the car. There is alot to the converter and gearing setup, as well as shift points, and all the other fine details.
Just keep chipping away at it, and you'll get the combo dialed in.
Old Sep 28, 2004 | 11:24 AM
Dragaholic's Avatar
9 Second Club NA
Ohhh, I thought you ran those times cam only. Im trying to break into the 10s naturally aspirated, stock heads, completely stock bottom end, stock cubes, etc. with the acception of a cam. I was thinking something wasnt right because your name would of been on the cam only list.
Old Sep 29, 2004 | 09:32 PM
GeorgeC's Avatar
Nope, I had GTP heads at the time (which I think were crap, but that's another story)...
My point was simply (and I wasn't trying to come off as a know it all or anything) that sometimes you just need to work with what you have and make small changes to net great results...
