Drag Racing Tech
Battery hold down bracket suggestions?
Old Sep 28, 2004 | 01:25 PM
DrkPhx's Avatar
Question Battery hold down bracket suggestions?
Hi,
I did a search and couldn't find anything good. If you use a battery hold down bracket, any information including pics, where you bought it, etc. would be appreciated.
Old Sep 28, 2004 | 02:07 PM
SilverGhost's Avatar
Motorboater
is this for relocating to the rear?
i have the jegs polished sealed and vented aluminum box, bolted through the floor of the car.
Old Sep 28, 2004 | 02:27 PM
DrkPhx's Avatar
No. Stock location.
Old Sep 29, 2004 | 07:23 PM
firechicken_98's Avatar
I was curious about this as well since the factory hold down doesn't work well. The tech guy wiggled my battery and it came completely loose.
A guy at the track with an LS1 used a 1/4" thick piece of aluminum band that he bent to fit over the battery. He bolted it down using the stock battery bracket screw and a screw that was by the headlight housing. It didn't look the greatest, but it got the job done.
Old Sep 29, 2004 | 07:41 PM
DrkPhx's Avatar
Mine was so loose when I launched at the track the battery would tilt backwards and short the electrical system (complete shutdown) because the positive terminal touched the A/C condensor bracket. Which resulted in several aborted runs.
I like the above idea for a bracket, but will try to include another bracket that will keep it moving side to side. Thanks.
Old Oct 2, 2004 | 07:45 PM
Chevy4Life's Avatar
I just went down to Schucks and got a Universal Battery hold down. got the job done for the track and looks decent too. It cleared the hood, but I'm planning to cut the bolts down a bit to be safe. See Picture below
