Drag Racing Tech
Rear spring question????????????????
Old Oct 1, 2004 | 05:45 PM
ss1le02's Avatar
Default Rear spring question????????????????
Of these springs, which one will help me launch the best? I'm thinking the stock SS springs.
Stock SS springs
1LE springs
Eibach Pro Kit springs
Old Oct 4, 2004 | 02:42 AM
AL SS590 M6's Avatar
Stock SS springs
1LE springs
Not much help but I run the stock Formula springs with 1/2 a coil cut off the top and with the cushions still there.
Rear needs to be just stiff enough to not squat on launch. Keep in mind that I have my rear QA1s set at 6 lh and 7 rh.
Old Oct 4, 2004 | 01:01 PM
BLK02Z06's Avatar
I have had both the Eibach pro kit and stock springs w/ a coil cut off. I had the same 60 ft. with both. Went back to the stock spring for a little extra clearance.
Old Oct 6, 2004 | 12:45 AM
ss1le02's Avatar
I going racing this w/end. I thought I wanted the rearend to plant(soft spring). I have the Eibachs in now. I thought I'd switch them out with the SS springs to get a good launch. Any tips
Old Oct 6, 2004 | 01:02 AM
Steve Burger's Avatar
LS1TECH Sponsor
Depends on how your car weight transfers. Mine transfers well with the stock rear springs and I have been setting hy hals at 7 and 8. If the car squats too much you are leaving 60' time on the starting line.
Old Oct 6, 2004 | 09:24 AM
SilverGhost's Avatar
Motorboater
I'd use the stock springs..
Old Nov 12, 2004 | 11:18 PM
99ssleeper's Avatar
Use what 99SSleeper uses.
