Best Launch Method for M6 w/ ET Streets.....
As for the Hals, I ove mine and the work great after 2 years and lots of passes. I run them all at 5 on the street and have very little bounce. When I race I set the ffonts at 2 and the rears at 7 and 8. If I forget to reset the rears to 5 I get lots of bounce on the street.
As for the 2 step, I wil let ya know. Just got an email today from Harlan that mine shipped. It took over a month but looks like I wil get it. I should have results from the 2 step in a fw weeks. I have dumped the clutch with the shift light on. No big deal except for the hold on factor. Don't worry about that. I have done it 10 times in the past 2 weeks. The Moser is holding it.
Hal shocks and springs all the way around(stock springs in back)
BMR everything: K member, extreme tq arm, lca's, sfc's, stb, panhard rod, and anti roll/drag bar.
When I got my ET Streets, I started at around 4500 and worked up to 6000 to get used to the launches.
Have fun!
Nothing I am not used to now but that first trip was indead a trip.
If you are going to put hals in the front, run their springs, you will not see nearly the full benefit of the shock if you do not.
