ET Street 26x11.5x15 vs. ET Drag 26x10x15?
I ordered a set of Bogart’s for the track. I have no experience with slick. My car is an m6, 12 bolt with 411. I will be doing a H/C mod in a few months. I like the idea of being able to install my track tires (maybe ET street 26x11.5x15) at home and then drive to the track, but I am not sure if I would be better off with ET drags and just change them at the track. I only want to run a 26’ tall tire so I don’t have any fit issues.
How do ET Street 26x11.5x15 compare to ET Drag 26x10x15?
These tires would only be use for the track. Is there much difference in the 60’s?
What do you recommend?
Any recommendations on the differences of the ET Street vs. the ET Drag 60's?
Is there a tire that will work at the track that is DOT or should I just get a 26x10x15 slick?
Krazy98Z28 you got a big difference between ET Street and Drag. I am shouting for low 1.6’s. What kind of differences could I expect between streets vs. drag in the 1.6’s?
Is there any other 26-inch tire that I should consider?
