NHRA rules to run low 11's in a convertible?
I am close to making it into the 11's with stock internals, and hoping for low 11's with H/C mod.
I have order a 6 pt chrome moly roll bar from Wolf, what else is required to be legal to run into the low 11's with a convertible?
see you jumped right on that sale.I run at an IHRA track 11.49 to10.99 helmet drive shaft loop.single layer jacet. 5pt seat belt. under pully. open wheel lugs .but it all depends on the track and events . most tracks are pretty relaxed as long as you have the major stuff .
7 Second Club
Location: Gainesville, Florida # of drag strips runs: ?!?!?
1 Post
check out http://www.nhra.com/tech_specs/ETQuickRef.html The new rule books should be out soon as well.
Basic list for NHRA: 5-point harness, Snell 95 or better helmet, longer wheel studs and open lugs, driveshaft loop, battery cutoff if not in stock location, as well as a few others. Hit the 10s and you'll need a full cage instead of the bar!
Derek
Derek
2010, bar, basic, cage, converible, convertable, convertible, convertibles, drag, nhra, race, racing, requirements, roll, rules
