What to do for Wolfe 6pt base plates?
If I make my own base plates does anyone have some dimensions/material I should use?
Good luck.
Charlie
NHRA rulebook gives the min spec on the plates/bolts:
Unibody cars with stock floor and firewall (wheel tubs permitted) may attach roll bar with 6-inch (15.2 cm) x 6-inch (15.2 cm) x .125-inch (3.2 mm) steel plates on top and bottom of floor bolted together with at least four 3/8-inch (9.53 mm) bolts and nuts
Good luck.
Charlie
