Am I doing a burnout correctly?
Anyhow, this is how I do it:
Go around the water box so that I dont get the front tires wet, then back up until the back tires are in the water box, put it in 2nd gear and give it a quick spin to clean them off and to get them wet, scoot up, apply my brake, flip the line lock on, slowly start spinning the tires until I know theyre moving, wait till I see white smoke, then lighten up on the throttle and release the line lock, and let the tires bite and scoot up to the line.
I prefer to snap them loose personally. I roll thru the water...spin the back tires to get them wet...creep up. apply linelock. put in 2nd gear. rev to 6k pop clutch and let them spin
What he means by 'snap the tires loose' is dump the clutch on a manual, you'll shock the tires harder and get them to spin easier.
TwnTrboCE, is your car an auto or manual? You describe how you do your burnout a lot like how pro dragsters do it.
Outlaw, I only spin probably 2 to 3 complete turns. Thats just a guess because I do it for probably a second to clean and get them wet. But I understand what youre saying and it makes total sense, and if indeed it does drip onto the tires or the track, do you think a few drops will make a difference in traction?
You may not see the small amount of water that might drop as being a problem, BUT if your learning how to do a burnout, might as well learn to do it right and then you will be set, trying to relearn something as you come up with more power can be hard. Also keep in mind, you are not the only one on the track, water may come off your car and be a hazard to the next racer whom it might really affect.
Just something to think about….
