When to lock up the converter?
Yank uses a light weight piston that isn't built for being locked up under wide open throttle.
Aren't you running a 200R4? If so, the main problem you have is trying to compare what you car is doing to a 4L60E..
Psst.. big hint for you.. all LS1 4L60 converters are "lock up" converters. They are designed for drivability reasons to lock at part throttle.
I do not think it is a good thing to do. It will put way too much stress on the converter lockup clutch.
See link below:
https://ls1tech.com/forums/showthrea...Lock-Up+Clutch
The problem is you ask 5000 questions, then never listen to what someone tells you. Usually asking the same question time and time again.
Then when you do something totally off the wall and it doesn't work, we get 500 more questions as to why it didn't work..
IMO, talk/type less and read/listen more.
Everyone else -- leave him alone, I want to see if he digs himself a grave.
tell nmra p/s racer Rich Groh that locking the converter is NO advantage. he will laugh at you.
Nine jillion posts on how to split hairs.
