2 step questions
http://www.harlan-engineering.com/store/store.html
Has anyone ever bought one from there and if so how long did it take to recieve after payment.
anyone got any more info than on that site.
any pics of 2step and/or intallation pics.
how does it connet to coils any cutting?
David
This time of year is good, as everyone is rebuilding/resting and I can actually build stock.
You can hit me up w/ a PM or email if you have any specific questions.
How do you have your 2 step wired?
Is it armed every time the clutch is depressed?
Do you have another switch?
What RPM are launching with the turbo?
Sounds like a good idea.
If you were just going to wire the 2-Step by itself for an M6 car you would not use the yellow wire (just coil it up and leave it alone) and forget all about the relays. For a 98 M6 car you would have to fabricate your own clutch switch for the grey wire.
On an automatic car you would permanently ground the gray wire, and run the run the white wire to your transbreak.
SlickVert, all you do is depress the clutch, and hit the momentary switch. The 2-Step is armed untill the clutch pedal is fully releases (90% released). I used the NX Switch panel for the mementary switch. The Left switch is Nitrous Armed and Bottle heater like normal, the middle switch is purge, and the switch on the right intended for the remote bottle opener I used for the momentary switch. After you finish your burn out, depress the clutch, click the mementary switch and then creap up to the line. The clutch needs to come up pretty high to disarm the 2-step so it leaves you enough movement to creap to the line and stage.
If you're going to run on the Nittos, why not let the 2-step hold you at 2900 but on 50% throttle. This way you can feather the gas a bit off the line rather than hitting it with everything you got.
UPDATE: Well, I just bought MT Street Radials...so.....maybe now it will be easier with a Two Step! Thanks for your input.
When you push the momentary switch do you have to hold it until you launch or just push it once to arm it and the clutch disengage will disarm it?
Great info,
Thanks
Great info,
Thanks
David
www.lifeinwidescreen.com/nbm.avi
I am using Cmotorsport Level 2 4L60E (if this one blows Rossler here I come), with a Line Lok and Nitrous. I would like to get a H2S, and wire it, so I can arm the Nitrous switch, burn out and then roll to the beams, hit one switch and : Line lok, check; Nitrous Armed, check; 2 Step, check! Foot on floor, hold it mid 2/3 yellow and release switch, unlocking brakes, spraying nitrous and full rpm rollout. Since I am not using a transbrake, I would set the rpm lower as to not creep thru the beams. I hate wiring!
Charlie
Charlie
