Drag Racing Tech
Launching Off a Two Step
Old Jan 24, 2005 | 02:52 PM
1ScrudeDude's Avatar
Default Launching Off a Two Step
With my M6 Z28, I am looking for input, especially from racers who use a Harlan Two Step for launching.
I love the unit because it holds whatever rpms I want at the line. Now, the typical operation calls for you to engage the unit by pressing the clutch in and holding the gas pedal to the floor.
I do this, but I have been wheelhopping like crazy in the 60 ft. I even dropped in some BMR LCA's, but I'm still bouncing off the line.
Now I have been setting the Two Step at 2600-2900 rpms on 18 psi Nittos and a Spec 3. I think my wheelhops are because I need to dump the clutch at a lower rpm since I have the engine at WOT as soon as the clutch is dumped. (And this is how the unit is designed to work).
So I'm thinking with a Two Step, successful launching is different than a normal holeshot. It would be more of an "aggressive rollout" vs. the traditional launch.
Am I thinking on course here? I am now scrambling to get full slicks but don't want to spend more $ since my Nittos are new. On my next time at the track, I am thinking of launching at around 2000 rpm at WOT instead.
Your input is wanted. If I can get a 1.8 or lower 60 ft., I am in the 11's. Help me get there...
Old Jan 24, 2005 | 03:57 PM
bad2000ss's Avatar
I really have no experience launching with drag radials, but perhaps a set of slicks would be better for your purposes. I don't think there would be any benefit to setting the 2-step to a lower rpm. It seems to be all about your tire choice.
Even though your are starting your launch at 2900, as soon as you dump that clutch the motor will overpower the drag radials and either spin them or cause them to wheel hop. If you want to continue to use the nittos perhaps you should invest in a decent torque arm and a set of rear shocks.
It looks like you have a 12-bolt, why continue to use the nittos? Get yourself a set of slicks and set the 2-step to 6000rpm.
If it still wants to wheel hop, sell the car.
Old Jan 24, 2005 | 04:49 PM
Yup, I think you are right, slicks it is. I got Nittos to be nicer to the 12 Bolt and to avoid loud whine. But since I have wheelhopped the **** out if it, it whines loud now!
It's easier and cheaper to go with tires than to change out TQ arm and shocks.
ET Streets?
Thanks for your input.
Old Jan 24, 2005 | 04:57 PM
Fireball's Avatar
yeah...launching on slicks is better suited for what the 2-step gives you...rev...foot to floor, dump clutch
you need more of a controlled launch on DRs.
Old Jan 24, 2005 | 08:02 PM
Decision made. Yeah, it's hard to slip the Spec 3 too, so here come the baldies.
Any suggestions while we're on the subject? The Z28 is not a daily driver and will see action on the street and strip...
Old Jan 24, 2005 | 08:10 PM
Loudmouth LS1's Avatar
Hey Tom, i'd say while still on ur nitto's, try coming off the two step at like 3200 rpm, might give a little spin and then hook up and go, it's worth a shot, 6-speeds want a little spin most of the time anyways or they'll usually bog from what I understand. Does it feel like ur boggin down when you drop the clutch? I'd say the wheel hop is being caused by the nitto's and the low rpm clutch dump, wheel hop is when the tire is like fighting to grab traction, kind of gettin it and kind of not, then it starts to bounce the crap out of the rear. So try some different settings, go up in 100 rpm increments until it stops and see what kind of 60' you get out of her! It's all about trying different things man, that's why it's test and tune!
Old Jan 25, 2005 | 01:03 AM
bad2000ss's Avatar
ET Streets?
I would deffinately go strait to a true slick. I'm not sure about anyone else with an M6, but I had a hell of a time trying to hook on ET Streets. The ET Streets would spin and grab about 4 times before they would hook. My best 60' on 26X10.5's was 1.695. I've read about many other people with manual cars having the same trouble with the ET Streets.
That rear end is gonna whine no matter what you do. Mine started out quiet, but the more I pounded on it, the worse it got. There's a really simple fix for a whiney rear end, turn up the radio, or dump the exhaust at the axel.
Shocks are a lot cheaper than you would expect. I spent $80 on the Comp Engineering set I have in the back. If you are going to be strickly drag racing, they are a great buy for the money. No need to spend $250 on the 12 way adjustable QA1's. You will most likely have to change out the toque arm eventually. Mine only lasted a couple passes on slicks before it twisted like a beer can. The stock aluminun driveshaft went the same way. I also blew out the bushings in the stock lower control arms.
If you plan on launching hard, plan on replacing the stock pieces, they will eventually give up on you. I did everything backasswards compared to most people. I upgraded all the suspension before any horsepower mods. Some people push the limits of their stock pieces. Mine could barely keep up with the stock motor.
Good Luck and have fun,
Old Jan 25, 2005 | 09:09 AM
Thanks Devon and bad2000ss, both ideas are taken into consideration. I am leaning strongly towards getting much stickier tires, because I will be needing them later (hopefully this Fall) when I put a 100 wet shot on her (and keeping the 4.10s).
And in the meantime, I will see if I can get the Nittos to work for me. I think the big part of the wheelhop problem is that I am not waiting for the tires to bite before getting on it. That's hard to do, being that I dump the clutch at WOT with the Two Step. So I should:
- Dump clutch at ~3200 at WOT
- slight spin
- lift throttle momentarily
- wait for hook
- back to WOT
That's kind of how I see it. Please note that on my last pass that night, I spun badly off the 2600 rpm dump, waited for a bite, I felt it hook (sort of), then spun the Nittos again for the 2nd time.
But again, it was late and dew was forming on the car roofs, so track conditions could have been the "X" factor in this case.
Old Jan 25, 2005 | 03:23 PM
- slight spin
- wait for hook
- back to WOT
I would definately say get slicks, but in the meantime, while you have the nitto's, try different ****. Try and get the perfect launch rpm, where they spin just a slight bit and then hook up w/o letting off the gas if that's possible with nitto's.
Old Jan 25, 2005 | 04:37 PM
Thanks Devon and everyone else for your guidance and time.
I just ordered MT ET Street Radials!
Old Jan 25, 2005 | 05:53 PM
Cool, I hope they work as good on f-bod's as they do on mustangs, heeh!
Old Jan 26, 2005 | 11:54 AM
mike c.'s Avatar
bad2000ss-man i feel your pain.i broke my tq-rm,rearend,lac,driveshaft,bant a rear shock,4-clutches and 4-trans. i know i'm forgetting something......
Old Jan 26, 2005 | 01:53 PM
NOTE TO SELF: Do not let wife see mike c.'s post
