TC advice needed
race weight shooting for 3300lbs
3.23 gears, may be swapping in a 9" & 3.90 gears
26x10x15 Drags (trying to get some 28s to fit later)
Cmotorsport Level 2 4L60E
Forged 346 shooting 200-300 out of the hole
Rear OE Springs, Hal shocks (upgrading to dbl adj)
Front HAL Drag Springs and R series
BADZ Solid End LCA's
Stock TA w/ Poly Bushing
Wolfe RC 6pt Weld-In
Harlan 2 Step hopefully wired in with Nitrous and Line Lock.
Currently using a TSP 231/237 112* cam w/ PP5.3L milled .010" heads.
Best 11.001 @ 122 1.41 (5600rpms w/26" IIRC thru traps)
Going with Cam Motion recommended cam (unless FMS or someone can recommend better) and will end up going with AFR 205's. I figure when I am replacing the bottom end I might as well throw in a fresh TC for the job at hand! Help me out guys.
Charlie
