Weight Reduction Help - Whos the lightest?
Remove all the interior, accessories, radio.. misc uneeded engine garbage.. emissions componenents.. safety equipment...
All that is free.
http://www.dxsoftware.com/magnus/pics/dash/dash1.jpg
Light cars can do these with very little power:
http://www.dxsoftware.com/magnus/pics/mycar2.jpg
What I did so far.
K-member, A-arms, QA1's,Aerospace components front drag brakes, racing seats, got rid of heavy 4" mufflex for a 3" dual setup with bullet mufflers and turndowns prior to the rear axle (that overaxle pipe weighs a ton).
Replaced normal battery with an optima (the optima is lighter), Fiberglass hood, removed everything under the dash including HVAC, all venting stuff like fan and heater core, Airbags, and all stock wiring from the car (probably at least 40lbs of wiring). I'm going to use a Gen VII standalone harness and rewire the car with a painless pro-street kit and a switchpanel. Removed the ABS stuff from the left framerail, got rid of the power brake booster, manual steering rack, ditched the power steering pump, got rid of the annoying alternator bracket that is heavy and got a Madman low mount alternator bracket. Next thing I gotta do is lighten the doors by cutting the side impact braces out. Got rid of the radio as well and took out the door speakers and back speakers also..... And I'm also going to do the Aerospace drag brakes out back and also switch from draglites to Alumastar 2.0's....I think that's it so far. If I don't get it down where I want it I'll order the VFN fiberglass hatch and the lexan rear window. That's like 100 lbs right there gone!
- ABS
- EBCM
- Extra wiring
- Rigging up a tubular bumper support
- Hoods / pins
- Lightweight carpet
The eventual goal is 3200 with me in it and a full tank. Currently sits at 3290 without me in it and 3/4 tank. I weigh 165.
I was looking at all your pics and that car looks great. How much trouble was it to relocate the adjuster for the alternator belt only. I have removed the entire a/c system and want to remove the power steering and water pump.
Thanks
Alan
I had a couple tools in the car also.
I am planning on ditching the air bags next..... and would like to get the light weight brake set up for the front at least.
I want 2850 by mid season.... 50 pounds away... not too far
https://ls1tech.com/nvss/pages/DSC01294.htm
https://ls1tech.com/nvss/pages/DSC01295.htm
