Drag Racing Tech
solid motor mounts
Old Feb 12, 2005 | 05:37 PM
speedracerz's Avatar
Default solid motor mounts
I have heard of solid motor mounts cracking aluminum blocks putting out alot of torque. anyone have any info to back this up. obviously with such a concern a plate would be the way to go, but for the class i am building my car a plate isnt allowed.
I want to run solid mounts but i now have this concern to address. now i am leaning towards poly mounts and maybe add some limiters to the engine and the trans.
input, thoughts, ideas all are apreciated.
this is a high hp, high compression, n2o beast leaving from a trans brake.
Old Feb 12, 2005 | 05:43 PM
brandonppr's Avatar
I have solids on mine. I think the main thing is to make sure not to get a solid trans mount also. I have a poly trans mount. I have only made about 50 passes at 7.51-7.64 1/8th but I don't see any problems as of yet.
Old Feb 12, 2005 | 05:44 PM
DERTY's Avatar
The Bull
I run Spohn solid motor mounts and never had a problem. Harlan ran Madman solid motor mounts two years ago and cracked a block. The two types of mounts are radically different, so it's not entirely a fair comparison. Also, I do not believe Madman even sells them anymore. If you are worried too much about it use a poly mount with a torque strap.
Old Feb 12, 2005 | 05:48 PM
how much power out of those cars? i am going to be putting out 1000hp or so and hopfially tq wont be far behind
Old Feb 12, 2005 | 05:57 PM
DERTY's Avatar
The Bull
800+ For both of the ones I mentioned.
Old Feb 12, 2005 | 06:12 PM
what's different between the spohn and the madman?
what exactly are you refering to as a torque strap? is that limiting the bushing or are you refering to a tq limiter?
Old Feb 12, 2005 | 06:15 PM
DERTY's Avatar
The Bull
The Spohn motor mount uses a significantly thicker top and bottom plate, larger gussets and a larger primary support tube.
A torque strap is a piece of strapping that you bolt typically to the cylinder head and tie it into the frame rail. This prevents the engine from twisting under torque. Call it what you want.
Old Feb 13, 2005 | 03:52 AM
thanks for the help, not sure which way to go yet.
Old Feb 14, 2005 | 11:51 AM
Silent but Violent's Avatar
I run the Sphon also. Very nice pieces. Pics on my webshots page....No problems
Old Feb 15, 2005 | 11:42 AM
Loudmouth LS1's Avatar
Spohn's here too!!! No problems as of yet and i'm launching off the t-brake on spray!
Old Feb 15, 2005 | 12:21 PM
JS's Avatar
JS
How much more vibration did u see w/the solids mounts.
I already have a tank-type race car so alittle more noise,vibration is no biggie
Old Feb 15, 2005 | 06:29 PM
I have no idea, the car is too loud too feel anything, hehe!!!
Old Feb 15, 2005 | 09:22 PM
69chevy's Avatar
ive heard that you're supposed to use a solid transmission mount with solid motor mounts. maybe its different for certain applications. just curious though
Old Feb 15, 2005 | 09:40 PM
well i am going to run is the poly mounts and dual engine limiters. and no never run both solids, you will snap off the tail shaft of the tranny if you are making any serious amount of power.
Old Feb 15, 2005 | 10:18 PM
DERTY's Avatar
The Bull
Do not run a solid trans mount with the solid motor mounts. You might find that to be a little bit too much stress for that setup to deal with.
