Drag Racing Tech
Good idea or bad idea?
Old Feb 23, 2005 | 12:26 AM
mnc2886's Avatar
Default Good idea or bad idea?
I am doing a solid roller setup that should spin to 8000 rpms. With a 28" tire and a 3.73 gear, the car pulls to 179 mph in 4th gear (I'm keeping my 6 speed). With a 3.42 gear, it pulls to 150 in 3rd gear. I want to be able to play around on the street with as minimal taction issues as possible, and I will be on et streets on the street. I'm hoping to trap around 145, so would it be a good idea or bad idea to spray of the line enough to compensate for the torque difference between the 3.73 and the 3.42? I would barely use 4th gear in the quater with a 3.73 gear, so I figure only shifting twice would be efficient. Not to mention, it would be a window switch, 75 off the line then probably 125 the rest of the way. What do you'll think?
Old Feb 23, 2005 | 11:56 AM
Loudmouth LS1's Avatar
I think that if your car is actually going to trap 145 in the 1/4, then you shouldn't **** around with it on the street!!!! But that's just my personal opinion, too each his own!!!! And for best performance, go with a gear/tire combo that will be close to maxing out 4th going through the traps.
Old Feb 23, 2005 | 06:23 PM
Stu'sWS6's Avatar
What tire height measurement are you using to calculate your max speed in each gear? Keep in mind that a 28 inch tall slick grows quite a bit more than a similar sized et street. I'd keep the 3.73's-179 mph in fourth is plenty fast for highway blasts-too fast even. If you really have a death wish; slam fifth-I've had to do it a few times on the street (4.56, 28x10.5 mt et drag).
With the kind of horsepower you are talking about (guessing 8-900rwhp) hooking on the street with a t56 is going to be a problem; regardless of what gear you are running. I'd try a progressive controller for the n20.
