is an upper PHB needed for my setup?
i was wondering if the upper phb is of much use with a full aftermarket rearend and suspension setup? i will be putting in a Billingsley Fab9 with anti roll bar, Wolfe dbl. adj. LCA's and PHB, BMR X-treme T/A, and dbj. adj. shocks and appropriate springs for drag racing, and eventually a set of wheelie bars. i plan on running 8's by next year, and hopefully 10's this year. i don't want to compramise safety, i just want to know if it's needed or just extra weight.
thanks,
Dave
Some guys need it other dont but it looks like u 6sp guys might benefit from it?
I dont have one and my car goes POKER straight???
That "Upper" PHR serves as a lateral support for the PHR Frame bracket under hard cornering, but can flex under hard launches (more than OEM intended). Trending Topics
big torque loads.The whole bracket will flex, trust me.
I'm not guessing on this, it's a fact.
Since he is talking about a high HP/TQ combo, if it does a big wheelie
the car will NOT go straight which can be dangerous if he rides it out.
I thought I should warn him.
But hey, no one listens to me anyway.
<<< big wheelie car, aftermarket lower PHB, no upper PHB, Madman suspension tuning = straight launches
U dont need the upper...
not talking about high 10 second cars?
I ran 9's and it's a little crooked, not much, but a little.
In still photos I can see the passenger tirebuckling under
and the drivers tire buckle outward.
I didn't figure the problem out until I noticed my drag bar had slid over
and my drivers tire actually hit the wheelwell.
When you do 100 wheelies and you see nothing but sky, the last thing I
want is for this guy to come down and be in the other lane or land on the wall.
Do you think I'm just making this **** up?
YOU have never even ran 10's in your car, you needed a driver, so
stop acting like a know-it-all. Ok?
Thanks
That bar weighs like 4lbs, on a street driven car if you slide into something it wont take that much to buckle that flimsy sheetmetal the PHB attaches to on the frame. At the very least put a bolt and some tubing as a fake bushing in the upper hole if you are going to take it off to box it a little better.
wish I could pull wheelies like Sean
Most all the other 60's are 1.33 tripping the lights with the rear tires. I don't think it is necc and I remove it from all the cars that I work on. Multiple 5 sec cars in the 1/8.
later,
Dave
My motor is just fine and I have 50 nitrous passes.
