Started Minitubing today
I should have pictures of the passenger side on our website in the next week.
To take full advantage the rearend will need to be narrowed as well as other possible modifications to some of the suspension mounts (that will depend on your wheel and tire combination).
Dan
http://www.ls2.com/forums/showthread...36#post3139136
David
David
Right Here
car looks BAD *** with the tires all tucked away. exactly what i wanted to accomplish.
what size are the tubs themselves?
Mine are a little longer, same width, really just a cut to fit deal, No "kit" available as of yet...that I know of anyway...although I did make my final templates out of aluminum. Very time consuming to do it right,
Step 1 Cut
Step 2 Fit
Step 3 repeat steps 1 and 2 many many times.
David
Both the cars mentioned on this thread look great.
apparently so man
i did a coil over conversion in the rear so that i can lower the back of the car and use mini tubs to get the look that these 2 cars have. thats the main reason, not because i think i need a 90"x105" tire. that and my rearend is shortened. man, lots of haters on this forum hahaha.
any updates? did you put the tubs in yet?
Link to some photo's: http://www.wolferacecraft.com/instal...odminitub.aspx
It will be large enough to fit 315/60/15 drag radial on a 12" wheel, which is the same size as a 29.5/10.5/15 W tire on a 12" wheel.
To take full advantage the rearend will need to be narrow as well as other possible modifications to some of the suspension mounts.
dan
