Drag Racing Tech
Time for longer wheel studs... any suggestions?
Old Mar 13, 2005 | 07:24 PM
12secondv6's Avatar
Default Time for longer wheel studs... any suggestions?
Right now.... stock wheel studs in front.
I run Weld drag lite 15 X 3.5's with a 5/16th spacer along with the weld draglite lug nuts.
Local track (e town) says this is fine...
Another track (island) tells me I need longer wheel studs.
Might as well be safe...
What size wheel studs/ open end lug nuts would you all recommend?
Thanks!
Old Mar 13, 2005 | 07:42 PM
JRcamaroZ28's Avatar
i have the ARP wheel studs up front that Thunder Racing sales. I run a weld the same size but w/ out a spacer and they real close to what is legal for NHRA
JR
Old Mar 14, 2005 | 02:52 AM
DietCoke's Avatar
With a spacer only the GM long stud is long enough to technically be nhra legal.
Old Mar 14, 2005 | 07:36 AM
Fireball's Avatar
nope...still not 100% legal. The threads have to come thru 10mm and they do not. but they 'look' long enough since the unthreaded part comes flush with the lugnut
Old Mar 17, 2005 | 08:52 PM
Matt D's Avatar
Retired Street Racer
gm studs here. they are also a lot cheaper than the arp's. only problem is they are not hardened.
Old Mar 18, 2005 | 11:45 AM
Jeffs99SS's Avatar
Can these GM studs be picked up from a dealership. Anyone have a part number, or do I just ask for longer studs for 99 Camaro?
Old Mar 18, 2005 | 12:23 PM
JNorris's Avatar
Moderator
I am fairly sure this is the GM part number for the longer GM wheel studs
22551491
John
Old Mar 18, 2005 | 05:55 PM
Matt D's Avatar
the part number from JNorris is right. below is a pic. you can order them at http://gmpartsdirect.com/, for $1.39 a piece.
Old Mar 18, 2005 | 06:28 PM
JNorris's Avatar
Moderator
Will the stock lug nut covers fit over the longer studs?
John
Old Mar 18, 2005 | 07:25 PM
Matt D's Avatar
if you are talking about the plastic ones, then no.
Old Mar 24, 2005 | 12:37 AM
JRracing's Avatar
Ya they will just nock a hole in er! J/K i just put arp's on the frt of mine for 22.00 bucks. just do it & be safe. I used stock open lugs on my crager ss's for the street. Doesnt look the best but will work for now. Lets go RACING!
Old Mar 24, 2005 | 07:13 AM
SLowETz's Avatar
Be carefull w/these if you're running any kind of spacer. I was using these w/ 7/32" (~3/16")spacers on the rear w/15x10" 7.5"BS DragLites. Bent all 10 studs after only 1/2 dozen or so launches. As stated above... they are NOT hardened.
