Are 10's close??
I don't see any suspension mods. You'll need a set of good adjustable shock on all 4 corners (QA1's work fine-but there are better). SFC, adjustable LCA, a very good TQ Arm, and a good aftermarket rear sway bar. Look at some of the signatures of other 10 second cars. Go to their web pages. You can learn a lot by just reading other posts. A lot of these questions have been asked and answered.
To be on the safe side -- save up for an aftermarket rear end. You may get by with a few passes on the stocker but not many (if truly pure stock).
A good set of tires. The M/T new street drag radial is working good, or just go to a slick.
As you can see there is a lot of variables. Oh by the way, what's your weight, where do you race, altitude of the track, etc, etc.
Good luck
David
FRONT SUSPENSION
-BMR LOWER A-ARMS
-HAL “R” SERIES DRAG SHOCKS AND SPRINGS
REAR SUSPENSION
-BMR ADJUSTABLE TORQUE ARM
-BMR EXTREME DRAG BAR
-BMR TUBULAR CONTROL ARMS
-BMR WELD ON RELOCATION BRACKETS
-BMR ADJUSTABLE PANHARD BAR
-HAL REAR DRAG SHOCKS
