Drag Racing Tech
Single digit guys... What suspension??
Old 03-18-2005, 06:35 AM
DopeFedZ's Avatar
Front:
Bmr front end
Afco double adjustables
Bmr subframes
Rear:
Moser 12 bolt
Wolfe sway bar
Madman T/A
BadZ lca's and panhard
Wheels:
Weld Magnum Drags
Old 03-18-2005, 06:36 AM
LS1Tech Sponsor
MADMAN's Avatar
Billingsley
__________________
www.madmanandcoracing.com
225-343-9029
Old 03-18-2005, 11:13 PM
Dan / Wolfe Race Craft's Avatar
Originally Posted by B18B1LS1
Are the adjustable perches f-body specific? I didn't see them on the Wolfe's site anywhere. Also, are the springs Wolfe too? Thanks.
They are a new item we have just came out with.
Look at the bottom of this page (Mustang Mini Tub Kit) you will see an adjustable spring mount. http://www.wolferacecraft.com/instal...usminitub.aspx
We have taken that same adjustable mount and adapted it to fit for the upper spring mount on the f-body. This allows the use of a small diameter coil-over spring, and provides some ride height adjustment when switching between different size tires.
Some modifications to the stock upper spring mount will be required. Basically the upper cup that holds the spring in it's location wll need to be cut out. Then our spring mount can be welded in.
They are available, I just don't a good photo of them at this time.
Dan
Old 03-19-2005, 02:48 PM
LS1TECH Sponsor / 7 Second Club
GoldRust's Avatar
Stock front k-member
Qa1 adjustable shocks (front)
Koni double adjustable (rear)
Moser 12 bolt , spool, 33 spline star flanged gun drilled axles 3.55 gears
Hotchkis lowering springs
Custom anti-roll bar by Outlaw Race Cars
wheelie bars by ORC
Bad z LCAs
custom pan hard bar by ORC
Weld magnum drag wheels
29.5 10.5 15 rear tires
Old 03-19-2005, 09:24 PM
B18B1LS1's Avatar
[QUOTE=Dan / Wolfe Race Craft]They are a new item we have just came out with.
Dan [QUOTE
Same price? $150
Old 03-19-2005, 09:30 PM
Under criminal investigation for fraud
Chris@AP-Engineering's Avatar
Front:
Mark Williams brakes
Afco double adj shock
Weld 15x3.5 Magnums
Rear:
WOLFE RACECRAFT LCA's
WOLFE RACECRAFT torque arm
AFCO shocks
Wilwood rear brakes
15x10 Weld Magnum's
29.5 x 10.5w Hoosiers
Old 03-20-2005, 09:32 AM
[QUOTE=B18B1LS1]
Dan [QUOTE
Same price? $150
Sorry: No they are $100.00 for the pair.
Old 03-25-2005, 08:56 PM
GueSS Who's Avatar
As Dan said. I like the adjustability of them and they were fairly easy to install. I cut all the inner bump stop portion out of the car anyway. So it was easy to get to.
Old 03-25-2005, 09:22 PM
xxx
xxx's Avatar
Not sure if I was a single digit guy or not, never got to run the 1/4. But did some serious *** haulin' in the 1/8th.
QA1's all around
PA Racing K-Member
9" with 3.73's
MADMAN TQ Arm
Wolf Anti roll
Old 03-25-2005, 09:26 PM
LS1Tech Sponsor
Brady's Avatar
Front-
PA chromoly k-member and a-arms
HAL shocks
stock springs
aerospace brakes
Rear-
Billingsley anti-roll bar
moser 9" and 31 spline axles
mark williams center section (3.50:1)
aerospace brakes
MadMan torque arm
MadMan LCA's
MadMan PHB
Madman suspension tuning
other-
'glide
spohn driveshaft
wolfe cage
weld magnum drags with 295/65 drag radials
SBC with 88/98 turbo
3580#
__________________
1966 Chevy II twin turbo LS3 project
2016 Z07 Carbon
Old 03-26-2005, 06:58 PM
Ben R's Avatar
wheelie bars by ORC
Bad z LCAs
What were your short times with that setup Josh?
Quick Reply: Single digit guys... What suspension??
