What's the highest stall you would go with on a bolt on only car?
Originally Posted by JS
Correct....
A VIG3600 flash stalls about 4200 so DONT go above that w/a VIG or u will need a LU switch which is a waste for a NA Car.Marc I gotta tell ya the TP4200 is badass,very streetable and will get u at least .5 over your 2800..
True, good points, thanks.
but again the TP4200 is better for all out NA racing.
9 Second Club NA
If youre wanting an ultimate naturally aspirated setup, you better think much higher than a 3.73. A 4.10 with a 26" slick would be the minimum/starting point. Thats what most setups are. You have to decide whether you want this car to be strip/street or strip only.
My main focus is still spirited street driving and when I drive it I'm normally traveling over 60 miles away and Amoco premium is over $2.15 a gallon here right now.
I think I'd better stay away from the 4400s LOL.
I loved the VIG 3600 Marc,it worked well for me....
Is #7 pump the only way that one comes or does it have to be requested/extra cost etc?
Look at my "mod/et" data in this section and you'll see what the PT line of converters will do over the Vig 3600. Night and day even running well into the 11's with a bolt-on car. Although the #7 pump is a VERY good converter, the Yank is on a higher level. Good luck!
Originally Posted by BAIN
Man I love how the guys that haven't tried any other converter always say their Yank is the best converter out there
#32
I've had 5 different verters in my car all Yanks and VIGI's...
My Current Yank TP4200 is almost 96 percent efficient taking my trap rpm and using math along with tire hieght and rpm,say what u want buddy but IMO a 96% efficient converter is pretty darn good especially when take into account its a loose 4200.
YANKS ROCK!!!!!!!!!!!
#34
Originally Posted by madpwr1
so which one would you say is?
