Drag Racing Tech
How often do you change your plugs & oil on a drag car?
Old 04-12-2005, 09:33 AM
11 & 7 Second Clubs
Race Car Driver's Avatar
Can you imagine changing LS1 plugs, say in a F-Body, after every run? It would make you quit racing or give up NOS! Madman, we're only running a 200 shot, so I don't believe changing plugs after EVERY run will be neccessary. We'll do whatever we have to do.
See our new NOS setup at http://www.hollowayracing.com/firebird%20motor.htm .
Originally Posted by MADMAN
My NOS motor the oil gets changed every 10 passes or every weekend which ever is first. I also cut the oil filter open every time and see whats inside. Plugs get changed every pass. I also run Royal Purple.
My deal is if you cant afford oil, filter and plugs you shouldnt be racing.
Old 04-12-2005, 10:59 AM
LS1Tech Sponsor
MADMAN's Avatar
The main reason the plugs get changed every time is mine are a bitch to get to so I just replace them. Plus Autolite has free replacement.
__________________
www.madmanandcoracing.com
225-343-9029
Old 04-12-2005, 11:56 AM
11 & 7 Second Clubs
Tell me more about Autolite's free replacement program.
Old 04-12-2005, 01:01 PM
S_J_H's Avatar
a lot of us have removed the gargantuan heater box.This makes it a breeze to get at the pass side plugs. I can easily pull all 8 plugs in under 15 minutes.
Steve
Old 04-12-2005, 03:42 PM
chpmnsws6's Avatar
Steve
i should time myself from start to finish...... its SOOOOOO easy with all the junk removed
Old 04-12-2005, 06:01 PM
S_J_H's Avatar
never timed myself but I think 15 mins is actually WAY to long. I'll bet 5 mins if I was really hustling.
Old 04-13-2005, 07:57 AM
11 & 7 Second Clubs
Changing plugs in my '99 SS, with all stock equipment under hood, takes hours, no matter how good you are at it.
Old 04-13-2005, 10:17 AM
I ruin the end of films...
mongse's Avatar
Steve
It takes me longer to jack the car up than to change the plugs. All my turbo piping is above the plugs, tubular k-member and hardly any accessories in the engine bay. Actually, I do have to remove a pipe for the wastegate now. I stand by my 15-minutes though.
Old 04-13-2005, 02:02 PM
bad2000ss's Avatar
Steve
Yup, after the HVAC is gone, changing plugs is a breeze. The Thunder Coil relocation kit makes it even easier.
The first two times out using N2O we pulled the plugs and checked them after every run. After we were sure the tune was good, and we weren't burning up or fouling any plugs, we pull them at the end of the race day to check them out. The plugs are always fine, but no harm in checking just to make sure. We have 2 extra sets of Autolite AR103's just in case.
I'm also interested in the Autolite swap deal that MADMAN was talking about.
Old 04-13-2005, 03:17 PM
LS1Tech Sponsor
MADMAN's Avatar
Keep your reciept from the auto part store. Take them back when you need another set. The box the plugs come in say "2 year replacement".
__________________
225-343-9029
Old 04-13-2005, 03:28 PM
11 & 7 Second Clubs
I like the way you think, but I suspect that my guys will object after they figure out the scheme.
Old 04-13-2005, 03:31 PM
  #32
Camaro_Zach's Avatar
seriously, i would almost rather run a 7 cylinder the way that sucker is. i hate changing springs on it, the plug, let alone gettin in the tube to fill the cylinder with air so the valves dont drop, that was BY FAR the worst, because you cant just get it in like a plug, it took 2 of us, i held it in the hole while someone was up top of the car twisting it clockwise and i was holing the end of it as well as where it bent so itd go in. i hate the clutter that the stock cars have. Too much crap!
Old 04-13-2005, 10:43 PM
  #33
GueSS Who's Avatar
I change my plugs after every night at the races. As long as I am at the track I usually check them after every run but reuse them until I go out the next weekend or the next day. The reason I do is because it is cheap insurance. Plus with TR10s they get fuel fouled out really easy. I need to lean the f out of my motor for idel and that will help
As for oil. I do that every 10 passes or once a month.
Old 04-14-2005, 08:17 AM
  #34
11 & 7 Second Clubs
In the context of this thread, if you or anyone else change plugs after every run or race:
1. Your car is an F-Body that does not have all stock equipment under the hood, or,
2. Your car is NOT an F-body, but rather some other kind of car, such as my Firebird Pro Stock type car.
I am not sure whether this thread starter's car falls into my category #1 or #2?
Old 04-14-2005, 08:48 AM
  #35
agreed. If i had a 70 chevelle, id change plugs in the middle of the quarter because itd be so easy
Old 04-14-2005, 09:54 AM
  #36
11 & 7 Second Clubs
Or multiple times per run!
If I had a 70 Chevelle, I would send it to W2W and turn it into a bbc fi monster.
Old 04-14-2005, 10:34 AM
  #37
bad2000ss's Avatar
I believe Dragaholic's car falls under category #1.
Old 04-14-2005, 10:53 AM
  #38
only thing that turns me on more than a FI BBC is naked chicks.
Old 04-14-2005, 10:55 AM
  #39
"The Drag Racing Director"
Coach 02 A3 Z/28's Avatar
Now this is funny!
Coach
Old 04-14-2005, 11:18 AM
  #40
MARKSZ71's Avatar
i change my plugs once a year,change oil every 2 months of racing,now trans fluid it gets changed every 2 races
Quick Reply: How often do you change your plugs & oil on a drag car?
