How does pinion angle affect traction and launch?
Pinion angle is part of driveline alignment.
The goal of having your pinion angle set is to have your driveline in line. Correct?
John
I understand why it would be in relation of the drive shaft but I do not know why it would be in relation to the ground unless you are assuming that the engine/transmission and drive shaft are at 0 degrees in relation to the ground.
John
On this same car the crank shaft is lower than the pinion in the car. The driveshaft runs uphill to the pinion. If we put 2 degrees in with your method or the driveshaft method the pinion would be way down.
I need some relocation brkts
(tryin to rip the bumper off)
What about the location of the front torque arm mount?
Just goes to show that people are learning the importance of a well tuned suspension!
Our vernacular may differ but we think alot alike.
later,
maggie
UH...Well, actually it is. The exact same laws of motion apply...Velosity, acceleration, weight, mass, distance and time. Without Newton's Laws we could not begin to understand the dynamics of the forces influencing the actions of the vehicle of our sport.
Happy tunning,
Maggie
Happy tunning,
Maggie
I think I menioned a lot of misinformation on this subject. On a lark, I googled for "pinion angle". Here are the first 10 hits. I didn't look for quality sources or filter this in anyway - just the first 10 hits.
http://www.carcraft.com/howto/91758/
http://www.2quicknovas.com/happypinions.html
http://buickperformance.com/Pinion.htm
http://www.4x4wire.com/tech/pinionangle/
http://www.iedls.com/ptsetup.html
http://www.drivetrain.com/driveline_angle_problem.html
http://www.wolferacecraft.com/pinionangle.aspx
http://www.quickperformance.com/PinionAngle.html
http://www.maliburacing.com/ssm_instructions.html
http://www.baselinesuspensions.com/info/pinionangle.htm
More than half of them get it wrong. People who should know, like Jerry Bickel, Inland, and Driveline Performance mostly get it right, but, surprisingly, Wolfe doesn't.
