Drag Racing Tech
?'s on removing ABS block.
Old Apr 14, 2005 | 05:42 AM
tektrans's Avatar
Default ?'s on removing ABS block.
So how's it done? Need any parts? Anyone have pics?
Thanks
Old Apr 14, 2005 | 07:47 AM
Larry's Avatar
Here's a couple of pics with line lock and one before I installed line lock:
http://www.mustangmods.com/data/440/...8image0002.jpg
http://www.mustangmods.com/data/440/...8image0001.jpg
http://www.mustangmods.com/data/440/absdel.jpg
Old Apr 14, 2005 | 08:22 AM
tektrans's Avatar
Looks like you just kind of bypassed the whole thing. Looks simple enough. Great pics, thanks alot.
Old Apr 14, 2005 | 11:34 AM
Dragaholic's Avatar
9 Second Club NA
Not sure what your plans are as far as what youre going to do after the removal, but I used the Billingsley ABS delete block and it was a simple swap. You would then need to bleed the system.
Old Apr 14, 2005 | 04:41 PM
tektrans's Avatar
I ordered the Billingsley ABS block today from Speed Inc. Thanks guys.
Old Apr 14, 2005 | 05:03 PM
A3Z28's Avatar
i did mine without any kind of block, just altered some lines a littlebit, very clean install for sure,
Old Apr 14, 2005 | 08:21 PM
SJM Manufacturing Inc's Avatar
We manufacture an abs delete kit which includes a proportioning valve as well as a line lock.
They can be seen at www.sjmmanufacturinginc.homestead.com
Old Apr 15, 2005 | 07:03 AM
Larry's Avatar
Your kit appears to be for LT1 only?
Old Apr 15, 2005 | 08:02 AM
We designed kits for both LT1 and LS1 either using 4 channel or 3 chanel.
