Attn: PPL w/ SY3500 converter...
Need some advice/info please. What are your mods? What tires do you run at the track? Susp. mods and set up? Burn out technique? Do you stall it up? Or leave a few hundred RPM off idle? And what kind of 60' times are you laying down on avg.?
Mods in sig, I run M/T 26X10.5X15 ET Streets on 15X8 Weld XP's. Best 60' to date is a dismal 1.837
Susp. mods are: BMR adj. TQ arm set at 3*, BMR tubular LCA's, tubular PH rod, rear QA1 shocks set at "4", RR air bag set at 9 psi. I have the end links removed from the front sway bar when I race.
Any help/info/suggestions are greatly appreciated.
![Barf](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_barf.gif)
