need SERIOUS help!!!
Any advice to battle this horrid situation is greatly appreciated.
You obviously have more going on than the loss of traction though. Losing 10 mph shows something is way off. Good luck figuring it out.
however the vibration is most likely the driveshaft after i did a lil searching on here for you. as far as loosing 10mph.... maybe a compression test is in order?
funny thing is is ur spinning, so u might be making more power if anything isn't way out of whack, but yet ur loosing 10mph with more power?
thanks for the replies
otherwise that is odd. vibration most likely driveshaft, after that the cuprit could be in the rearend vibration wise.
if your MPH is really 10 MPH off, then you have something going on. My first thought would be maybe your new clutch is slipping like a **** on the big end, that would contribute to big MPH loss.
if it was slipping bad in the 60 foot there would be your loss in 60 foot, thus ET as well.
if the car is running the same..no SES lights or anything, I would really start with that new clutch, if its slipping bad it would cause both your problems.
I think you are only lossing MPH because of the spinning it sounds as if the car is running properly or you wouldent be ripping the tires
