Drag Racing Tech
basically stock M6 guys come inside
Old Jun 29, 2005 | 04:40 PM
1BAD_Z28's Avatar
Default basically stock M6 guys come inside
well my mods are in my sig and im running on GSC'S and i cant seem to 60 foot my car for the life of me. my current launch technique is a 2000rpm clutch drop. iff i try to slip the clutch as i have read my 60' time gets worse like a 2.35. i really want to get my car into the 12s before i do my heads and cam. heres my best run so far....
60'----2.23
330---5.94
1/8---8.8
mph--85.72
1000-11.3
1/4---13.3
mph--108.89
see the thing is my car isnt spinning so bad but it goes into almost a bog off the line and it seems like it takes forever for 2nd gear to come around.
any suggestions would be really appreciated
thanks
Old Jun 29, 2005 | 05:06 PM
LoPeY's Avatar
I know exactly what you're talking about. Try dumping at slightly higher rpms(200-300). You should get a bit more wheel spin which will keep that slight bog from happening once you hook since you'll be turning slightly higher rpms. Doing this took a tenth off of my 60' . Just practice and you should get it within a few tries at most. It only took me one try.
Old Jun 29, 2005 | 09:35 PM
SMOKIN01TA's Avatar
i pulled a few high 1.9's and mostly 2.0's on my stock gsa tires, left at 2500 and learned how to pedal it out.
Old Jun 29, 2005 | 10:15 PM
BlueSix's Avatar
Gotta learn to slip/pedal that biatch!
Old Jul 1, 2005 | 12:35 PM
1BAD_Z28's Avatar
thanks guys ill give it a try tonight
Old Jul 2, 2005 | 09:52 PM
92SilverSHO's Avatar
i just ran at the track for my first time, how did you cut a low 13 pas with a 2.23 60ft? im confused because i ran a 13.6@108.7 with a 2.195 60ft, but also ran another 13.64@107 with a 2.3, i dont get why i couldnt break into the low 13s at all! how can people run a worse 60ft than me and get into the low 13s?
Old Jul 2, 2005 | 10:33 PM
BlueSix's Avatar
Better driving, stronger car, better weather, maybe they weigh less....there's a lot of factors.
Old Jul 2, 2005 | 11:31 PM
well my trap indicates a stronger car, so thats not it, driving, i pull a better 60ft than what i see on some of the low 13 passes on the site, weather was perfect, track is only 100 ft above sea level, had a 10mph tailwind. nope im stumped!
Old Jul 8, 2005 | 07:45 AM
98TADRIVER's Avatar
some people shift faster/slower than others?
And Camaros are heavier than firebirds.
temperature? how hot was the car?
my first run was a 13.39, basically right off the highway 210 degrees temp
98 TA M6
SLP Lid w/ K&N
magnaflow catback
!MAF screen
60 foot 2.130
330 foot 5.750
1/8 mile 8.630 @ 85.490
1000 foot 11.030
1/4 mile 13.280 @ 104.190 MPH
messed up on 3-4 shift due to the 3-4 shift fork. previously ran a 13.3 @ 108mph on street tires with a 2.2 60' time
