please help me get better times
heres my mods (above times are w/o cam or clutch)
http://darmer.com/mods.htm
I got a new clutch (OZ700), installed my cam, got it tuned, and went to the track a 2nd time on Sat. With my new clutch and more power I have to learn how to launch good. I was hoping to get into the mid-low 12s but I barely got into the 12s.
Heres the video, go to "track runs 6-2-05"
http://darmer.com/videos%20main.htm
I tried reving up to about 2.5k and dropping it, and the tires spun.
I have 315/35R17 nitto DRs. I was running 15 psi, lowered to 12 and tires still spun fairly easily. (even when trying to not rev up and slip the clutch a little)
I was thinking I wasnt doing a good enough burnout but my tires seemed to be sticky enough. I have a hard time doing a stationary burnout, I just kind or did a rolling one up to the start. once on the burnout I started to traction hop.
when I shift to 2nd I spin a little.
I have a 9" but no slicks yet. I think if I can rev up, drop it and hook up decently it should help out my 60' times a lot.
the last few times I would spin off the line and start traction hopping very badly. I had to let off to stop and catch again. I didnt have this problem the first couple of runs but it seemed to start happening everytime.
my rev limit is at 6.8k, my shift light is set to 6.3 and I shift after I see it.
When I cross the 1/4 in 4th gear, my rpms are at about 5,700 I believe (gear calc). my car peaks at 6-6.5k http://darmer.com/dyno%20graph.htm so i think it would help if I can lower my gear somehow. I dont really want to change gears, I would prefer tires if possible.
the sources of my traction and time may be: stock torque arm, pro kit lowering springs, heavy rims/tires.
Basically I feel that I am not getting a good enough launch, and Im not sure what I need to do to fix it
What should I do about my gearing so I cross at a higher rpm?
what kind of slicks should I try to get?
according to the gear calc. my nittos are like 25.6" or something, so if I get 26" sized slicks that wouldnt really help on the gearing any.
I have my stock rims/tires, I think the rims are 16x8, would those rims be ok to get some slicks for, intead of buying some 15's
I think I want to get a line lock pretty soon to help on the burnouts
against smart judgement, Ive never checked my pinion angle w/ the stock torque arm, I will do that asap
what do you think about the traction hop though? is that a sign of a problem in the suspension (spring drop or tq arm setting) or not neccesarily
so would it be possible to get some good slicks in a slightly smaller diameter, or just get some in the 26" range? (I know people usually run 26-28 but I was trying to get a smaller tire to help out on the gearing)
As of right now I dont want to change the gearing in the axle
thanks for the responses
and how important is it to cross the 1/4 at the top of your power curve? If Im passing in 4th at 5.7k and I peak at 6.3k, how much is this hurting my times?
