Gtech sucks, track tested.
Took my GTech to the track, and it wasn't even CLOSE. I ran a 13.6xx and the G-tech said 14.2!! And, the Gtech said my MPH was like 104 and I was around 102. Almost identical both runs.
Over 1/2 a second off?!?!? Yes, it was perfectly balanced, set for 0.0 on a known level surface (and verified perfect zeroes on the level starting line) and it was pointed perfectly straight left-rightwise. A straight tilt showed 1.00 (so it was calibrated).
Boy did I get ripped off. Felt like bouncing this thing off the cement.
, I know that if the number changes that something is better or worse. Trending Topics
When the G-tech is pointing straight up/down (used a bubble level), it shows 1.00G (which is supposed to mean it's calibrated from what I understand). It's possible that the Gtech moved around during the run, but although I've used the G-tech only twice at the track, I have used it dozens of times out on a long stretch of nearly perfect level road, and it's been showing 14.1+ EVERY TIME (passes in both directions to compensate for possibility of unlevel road). So, there MUST have been at least ONE well-anchored mount all the times I've used it. I've NEVER seen it show a sub-14 time since I've owned it. Before I ran at the track, I was convinced there was something wrong with the car.
It's not the newest model, I got it for Christmas last year and it was on a closeout deal so it's probably a reasonably older model. "Maybe" the new ones are better, but mine is a POS.
