help, people running M/t 325/50/15 dr inside
How do you guys run these things. I have prostars 15x10 but I have to run a spacer how can I get away from that?Do you still use the stock brakes? What back spacing? Thanks in advance.
I use Welds with a 6.5 BS. No spacer needed.Wheels stick out about a 1/2 inch at the top of the fender but stick out more towards the bottom. Gets a little messy at the track during burnouts.
To run the tires your are talking about,You'll need 6 1/2 B.S. Depending on the type of rim,You may need to trim (gring) the brake caliper. Hammer the crap out of the inner fender & trim and curl the outside fender lip. Hope this helps.
