Weight Saving Ideas?
9...!ABS
21.5!AC compressor
8.5.!AC condenser
....!AC fan motor
13.5!Airbag and bracket, passenger's
4...!Airbag, driver's
....!Air dam
1...!Air filter
5...!Amp, Monsoon
4...!Antenna, bracket, and motor if applicable
....!Ashtray & lighter
....!Blinker switch
2...!Bolt lengths, extra
....!Brake pedal pad
23..!Bumper, front reinforcement and brackets
21..!Bumper, rear reinforcement and brackets
34..!Carpet & Sound deadening
50..!Catback
15..!Cats
9...!Center console
....!Coating, under carpet
4...!Crossmember brace
....!Cruise control
10..!Dash
20..!Door panels
11..!EGR, air pump, & harware
....!Emblems
....!Fan, 1
....!Fan shroud
5...!Floormats
3...!Foglights and brackets
....FRA mod
....!Gas, Extra
2.5.!Glovebox
1...!Grill insert
4...!Hatch cover
2...!Hatch shocks
....!Headlights
....!Headliner
3...!Head unit
....!Head unit/AC console trim piece
8...!Heat sheilding
9...!Heater core
1...!Hood shocks
3...!Horn
3...!Inner fenderwells, plastic
....!Liscense plate brackets
....!Liscense plate(s)
....!Misc. junk in the car like keys, garage remote, change, owner's manual, etc.
1...!Owner's manual
3...!Panels, under steering wheel
5....Panhard rod brace, upper
....!Parking brake
....!Power brake booster
....!Parking brake handle
....!Power seat motor
11..!Power steering pump, pulley, idler pulley
....!Power window motors
1...!Rear view mirror
9...!Seatbelts (rears and passenger's)
34..!Seat, passenger's
19..!Seats, rear
3...!Sheetmetal, extra double walled
....!Shifter ****
5...!Side impact bars
35..!Spare tire and jack
7...!Speaker panels, hatch
5...!Speaker panels, rear passenger's
15..!Speakers
35..!Spoiler (Weight measured on a Pontiac)
....!Spring isolators
2...!Sun visors
14..!Swaybar and brackets, front
....!Taillight(s)
2...!T-Top holders
....!Under car tow points
1...!Washer fluid pump
9...!Windshield washer fluid
2...!Windshield wiper reservoir
3...!Wiper arms
3...!Wiper motor
....!Wiring, Excess
Wallet mods....
3...Airlid, aftermarket
3...Chromoly LCAs
3/9.Carbon fiber driveshaft
14..Chromoly A-arms
30.5Chromoly K-member
....Draglite wheels
....Drag slicks or street slicks
....Drilled axles
24..Dry cell battery
10..Electric water pump
....Fiberglass door skins
30..Fiberglass hood
....Fuel cell
18..'99+ fuel tank for '98 cars
....Headers
....Lexan glass
....Lightweight clothing
35..Lightweight brakes, front
....Lightweight brakes, rear
10..Lightweight flywheel
13..Lightweight springs and shocks
....Lightweight steering column
6...Lightweight steering wheel
10..Manual rack and pinion steering
....Plastic fuel tank, late model
....Powerglide, TH350, or M4 transmission
17/29.Racing seat
....Shortbelt mod
....Skinny front tires
15..Spool
20..TQ converter, small
....Underdrive pulleys
pull the spare, jack -40
the rear seats -25
rear seat belts -5
AC system -45
egr, air -15
wiper resivoir -2
lightweight battery
stock location -10
headers -15
remove catback
dump before axle -30
theres just a few starters for ya.... for an easy 200lbs.
all comes to 3088lbs with me in it.
K-member
Hawker/Genesis battery
!exhaust, just to name a few weight reduction items
Good times!
how far do you want to go.....?
booooo v6 is lighter....
you had me for a second
