Drag Racing Tech
BIG LT1 headers?
Old Aug 7, 2005 | 11:41 AM
Carbed4thGen's Avatar
Default BIG LT1 headers?
Wat does everyone use for BIG headers? I'm gonna need like a 1 7/8 set. Does anyone make them? If so does anyone know where I can find them and wat PN everything is? I know Kooks makes a set but those are stepped. Does anyone make a true 1 7/8 headers?
Old Aug 7, 2005 | 01:06 PM
Birdie2000's Avatar
Hedman
Old Aug 7, 2005 | 01:17 PM
flyinZ's Avatar
Yup..What makes you think you'll "need" a BIG set?
Old Aug 7, 2005 | 01:22 PM
Umm the plans of goin 8.5's, heads that flow A TON, and VERY little street duty, so I was figuring go BIG or go home!
Old Aug 7, 2005 | 01:42 PM
flyinZ's Avatar
Ok then..that'll work,lol
Old Aug 7, 2005 | 02:05 PM
I figured so
Old Aug 7, 2005 | 04:33 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
PM Z8's, I think he has Lemons headers.
Old Aug 7, 2005 | 06:26 PM
Ok I found the numbers for the big Hedman headers here they are incause anyone else was wondering
#63585 true 1 7/8" 3.5
#63586 1 3/4 stepped to 1 7/8 3.5
Old Aug 7, 2005 | 07:25 PM
Birdie2000's Avatar
Keep in mind you need bolt pattern adaptors for these to work.
Old Aug 7, 2005 | 09:48 PM
Are u speaking for an LT1 or LS1 car? cause mine is an LT1
Old Aug 8, 2005 | 12:36 AM
Birdie2000's Avatar
Lt1
Old Aug 8, 2005 | 08:01 AM
Lt1
Y would I need a bolt pattern adaptor for those? aren't they just mad for an SBC car? which would be at LT1 anyways? and either way I'm dropping in a conventional SBC anyways
Old Aug 8, 2005 | 08:18 AM
Birdie2000's Avatar
Because the primaries are so big, the bolt spacing of the traditional bolt pattern will cause interferance with the tubes. They use a 18* bolt pattern and require an adaptor that may need to be ported to match the size of your header/port. You need something along these lines:
http://www.jegs.com/cgi-bin/ncommerc...09&prmenbr=361
Old Aug 8, 2005 | 08:40 AM
Ok ok, so is this with ALL big tubed headers? or just the hedmans? Like if I went with a set of the Lemons headers would I have to do that also? Or should I just call Lemon and ask them?
Old Aug 8, 2005 | 08:43 AM
Birdie2000's Avatar
You most likely would, it's more of a restriction set by the primary size interfering with those bolts cause of necessary clearances to spin the bolt and such. I believe some heads like the big-port AFR's can be ordered with the other bolt pattern from the get-go, but I'm guessing you already have heads with the standard bolt pattern.
Old Aug 8, 2005 | 08:25 PM
Does anyone have any pics of a set of 1 7/8 headers in a car? or maybe a carbed setup (4th gen of course) with some big primaries?
Old Aug 8, 2005 | 11:45 PM
ROBS SS's Avatar
call lemons they did a set for me that was 1 7/8 -2" step into a 4" collector they fit great
Old Aug 9, 2005 | 12:31 AM
Vortec355's Avatar
I am also interested in a bigger header then the conventional super comp hookers. I picked up a set of bowtie Vortec heads 215cc intake and 84cc exaust. The exaust runners are raised like a LT1 head, so wouldn't you need to modify the exaust flange to fit the heads or are the headers made for LT1 heads.
Old Aug 10, 2005 | 12:31 PM
N20Dave's Avatar
Another vote for lemons. I have 2" primaries (LT1 but with SB2's) and they fit very well. I had to make some mods to the chassis but that was due to the width and layout of the heads and not so much the large tube size.
