Drag Racing Tech
Battery Tie Down
Old Aug 12, 2005 | 08:02 PM
AW794's Avatar
Default Battery Tie Down
My stocker is broken, what are you guys running? I need one so i can run at my track. Thanks!
Old Aug 13, 2005 | 04:42 PM
AW794's Avatar
Did a search but found nothing...
Old Sep 7, 2005 | 09:44 AM
blkbird_WS-6's Avatar
I searched also and found nothing.
Old Sep 7, 2005 | 03:57 PM
tektrans's Avatar
I made an aluminum bracket a while back from some stock I brought from Home Depot. I had bolted it to the stock location and form bent it over the top of the battery and used one of the screws that hold the headlight assembly in place to secure it up front. I've since relocated the battery so I'm not using it anymore, you're welcome to it. Is there some way you could mail me a return box so I just could drop it in and send it back?
Old Sep 7, 2005 | 04:04 PM
GREATWALLTA's Avatar
Try to see if you can get a battery relocation kit for your can. I remeber seeing alot of sponsors carrys them. It relocates you battery to the back of the car inside the spare tire compartment, so you don't have that heavy weight in the front end of your already monstrous frontend. It is a worth wild mod for a track car like yours.
