Narrowing and backspacing.
You can fit W's with and without the axle being narrowed. The biggest advantage of narrowing is you can move everything in a bit, loose some of the weight and have an added bonus that you get the axles in the range of more commercial rim sizes that make the tires look nicer on the car. It's certainly not a huge improvement in performance, but if you have an axle that can be narrowed it's only a couple hundred dollars. And if you are buying a new axle, it's worth it to just get it shorter. BTW, 40 spline axles can not be re splined and you will have to get new axles if you are working with those. I'm not sure about 33 and 35 splines, but I think that most of them can be resplined.
As far as spacing, you can always use a spacer to push the wheel out a bit if you need to. But, I already know what you will not likely need that. If you move the LCA in that does not necessarily mean the spring needs to move in too. If you crawl in there and look you'll see that the LCA is more outboard of the spring. Simply pushing/offsetting it to the inside of the place that it bolts in gets you an extra inch of tire clearance. You can always go with a smaller diameter spring with the same spring rate as stock if you have to. They are very cheap. Billingsley sells them for around $60 a pair I think.
A .5" difference in backspacing is not going to make your dish look huge. A 15 x 10 on a 5 is still going to have 5" of dish as opposed to 5.5. But, you will see that the tire edge is outside the upper fender line which looks rather ghetto. I'd rather get the 5" BS and then mess with a small spacer if I had to. I had mine with no spacers.
If you look at some pictures that FastBlackTA just posted regarding his 3" narrowed axle and roll cage you'll see how nice everything fits.
David
Another buddy Z8's has 15x10/5.0 backspace/2.5 narrowed per side. I'm not sure if he has other mods back there to make that combo work.
What are you referring to as offset spacers? I'm running BMR bolt in relocation brackets and my Spohn LCAs and on the side that it bolts to the rear end has sperical rod ends and there are no spacers that I know of and there isnt any room to put any to offset it.
Thanks everyone so far for all the help.
You can probably pull the axles yourself and tell easily. If your thumbnail can grab the leading edge or you can visually see the outer diameter of the splines is greater in diameter than the rest of the axle, then you have to order new. If you order new, 3" shorter than what you have will work. Expect to pay a few hundred bucks for new axles, plus bearings.
You can offset any LCA that has adjustable rod ends on it. If you have a LCA that has bushings, then you need to wing it and either use those or get something else that can be offset. Offsetting the LCA is nothing more than mounting the LCA in the same place that you normally do, except that you have to slide it all the way inboard. Sometimes a 1/4" spacer will help keep the LCA off from the bracket (I'd recommend 1/4 to 1/2" spacer there). There is no bracket, it's nothing more than putting spacers on the bolt to make sure that the LCA lines up in the stock locations offset to the inside of the car. If you have a LCA that has the spacers pressed into the heim joints you need to take those out and replace them with spacers that push it over more in the same spot.
dragaholic...Give me a call on monday. I can help you with the Bogarts and get things straighted out...spacers and other varies questions...
...most of the guys helped give some pretty good pointers on the board...
...being that you are using our Bogarts, we are offering exclusive pricing for any strange components.
regarding LCA's, we do offer offset LCA's but are not listed on our website. If you already have rod-ended LCA's as Derty stated...it's pretty simple to modify what you have already.
Steve
SJM Mfg, Inc.
Bogart wholesale/distributor
412 508 0634
