Drag Racing Tech
Painless wiring harness
Old Aug 21, 2005 | 09:01 PM
JPJBC's Avatar
Default Painless wiring harness
Anybody running a painless harness for a drag only car? Im looking to do away with all non essential computer functions. So basically I need the engine harness and head and tail lamps and blinkers. Any other info on drag setups would be appreciated as well. Thanks
Old Aug 21, 2005 | 11:27 PM
Project_SS's Avatar
It not a Painless harness. We just modified our stock harness. You can read the post here
https://ls1tech.com/forums/showthrea...ght=project+ss
Old Aug 22, 2005 | 05:48 AM
JPJBC's Avatar
Hell yeah thats what Im talking about. I started to do the same thing to mine and thought man theres got to be an easier way. Thanks for sharing.
Old Aug 22, 2005 | 06:32 AM
GM Muscle's Avatar
I'm about half way through clipping my stock harness and it's not too bad. Things are actually pretty organized once you get all the harness' apart. I would keep pluggin away at the stock one. You can get the Painless one from Jeg's for $500-600 if you wanted to go that route. I'm not so sure that they come with headlight/tail lamp wiring though.
BTW: I'm not so sure that you can bybass the BCM with the stock harness, I have to look into that some more.
Old Aug 22, 2005 | 08:28 AM
Josh@KY-Turbo's Avatar
am am thinking of going the Painless route too. i am gonna run a DFI/Fast/BS3 engine managment system and dont want to use the factory PCM at all.
Old Aug 22, 2005 | 09:46 AM
Project_SS's Avatar
If you notice in the first picture you will see that we did remove the BCM. As you mentioned its fairly easy once you get started. just be sure to take your time and have the service manual.
Old Aug 22, 2005 | 10:33 AM
Carbed4thGen's Avatar
Do u have power windows? and if so how did u get rid of the BCM and retain the power windows?
Old Aug 22, 2005 | 01:13 PM
GM Muscle's Avatar
That's the problem, I don't have a helms manual. I'm stuck with tracing stuff by hand. So the ignition does not run through the BCM at all? What exactly does run through it beside air bags, power windows/locks, and the radio.
