Drag Racing Tech
Lightest battery for daily driving???
Old Aug 26, 2005 | 01:11 PM
CAT3's Avatar
Restricted User
So when I order my PC680 I need to order/get adapters also? Where/What? TIA
Charlie
Old Aug 26, 2005 | 01:38 PM
SUX2BU's Avatar
Charlie
I just pulled the rubbers and bolts of my battery conections and used the supplied bolts thay sent me.
Old Aug 26, 2005 | 07:45 PM
AnthonyConstant's Avatar
Originally Posted by al
Here is the battery I run http://www.gotbatteries.com/Productp...ctNum=37L105S1. I have had it on the car since March 25th (right at 6000 miles)and my car is a daily driver. I even have a underdrive pully and the car cranks everytime. I have stock electronics in the car and always have my stereo on and my lights and stereo on when I drive home from work. I mounted mine just like GM Musc. did. I made adapters so my stock cables fit.
So this will work on a 94 z28? can i just buy adapters , if so you got a link...
thanks alot....as soon as you verify this im buying right off your link! thanks!
Old Aug 26, 2005 | 08:07 PM
SUX2BU's Avatar
Don't get that one look at what it says in the product notes.
PRODUCT NOTES
For motorsports applications use the Odyssey battery. The Odyssey was designed for rugged vibration sensitive applications with thicker plates to prevent cracking and premature failure. The warranty on the Genesis doesn't cover motorsports installations.
Get this one. PC680
http://cgi.ebay.com/ODYSSEY-PC680-DR...QQcmdZViewItem
Old Aug 27, 2005 | 02:23 AM
al's Avatar
al
I`m sure it will work on a 94 mine is a 2002. I`ll send you a PM and we can talk over the phone on how I made the adaptors to make it fit my battery.
Old Aug 27, 2005 | 02:28 AM
al's Avatar
al
PRODUCT NOTES
Get this one. PC680
I notioced that when I ordered mine also. I bought it because several guys were running them in their cars here in Houston without any problems. Mine is cammed , but I don`t run it at the track often at all. You have a nice car by the way. I think I saw you post that you were down to 2800 lbs or so. Thats bad ***.
Old Aug 27, 2005 | 10:30 AM
SUX2BU's Avatar
thanx. yeah itd down to about 2790 with out me in it.
Old Sep 2, 2005 | 06:18 PM
CAT3's Avatar
Restricted User
Just ordered my Ody 680. Great info and resourcing in here.
Charlie
Old Nov 23, 2005 | 09:35 PM
Mr_president's Avatar
i got mine im going to intall it and maybe take some pics!!
Old Nov 24, 2005 | 10:33 AM
TMC's Avatar
TMC
Guys,
I have a couple 13lb batteries left for sale. They are the same size and specs as the dyna-batts and PC 680 but have flat post style terminals. I use one on my car with no problems and Slow3hoe2 from this board is using one in his DD Camaro. They crank fine and work good for DD's and have so far lasted a couple seasons.
These are brand new never used batteries that I'll let go for $65 shipped to you're door.
troy.m.carter@gmail.com
This is a pic of the one I have in my Mustang.
Old Nov 24, 2005 | 01:20 PM
aram's Avatar
I killed my original light battery after three cars and two years and draining it waay to many times so I bought a PC 625 (a little heavier) locally and it's worked fine since.
Old Nov 25, 2005 | 11:33 AM
  #32
Bryan @ Speed Inc.'s Avatar
TMC check pm's... i'm interested in buying from you.
Old Nov 25, 2005 | 12:23 PM
  #33
TS6's Avatar
TS6
I put one of the Odyssey 680's in the Z, it works fine but right now its about 35 degrees in the garage and this thing is barely turning the car over. I highly doubt its gonna work in the really cold (like in the teens) temperatures. If I put some kind of trickle charger on it will it help?
