et street vs. et drag
ET Drags 12.5lb air pressure =1.597 60ft.
ET Streets 15lb air pressure =1.519 60ft.
According to Mickey Thompson do a burnout to raise tire temp no more than 25 degrees higher than the temperature of the track surface. Any hotter or cooler and the tires grip less. During burn out keep tires spinning long enough to get some smoke going. If tires look shiny and greasy afterwards you have got them too hot. A good tire pyrometer or infrared handheld temp gun avaliable from Radioshack $50.00 works good at measuring track vs. tire temps.
I have to make a decision soon to.
My et streets are worn out. I can't decide between et streets and et street radials
The major differences between the 2 is the et street has more cords in it for a stiffer sidewall, and that along with the grooves makes for the DOT stamping. I've gone 1.48 60 foot on my 27.5" tall x 9" wide et street (listed as 28 x 11.5 x 15) on my Nova on a 100 hp shot of juice, FWIW, and they still drive decent on the street, although I air them up to 22-25 psi for street driving.
Derek
