Drag Racing Tech
What is the correct order to set up suspension?
Old Sep 8, 2005 | 10:20 PM
Loudmouth LS1's Avatar
Originally Posted by next
The idea is to be on level ground, not try to level the car. There are benefits to front vs. rear ride height, but I wouldn't focus on that yet. You want the car on level ground 'cause that's what the track will be like.
If you have adjustable LCAs you can start with squaring the rear end by measuring from the front of the door jamb to the center of the rim/axle. Simple as making both of the equal.
You do want a uphill rise in the LCAs but your only real adjustment is going be raising/lowering them in relocation brackets, so I don't know how 2* could be exact.
Not sure what you mean by get differential straight with the LCAs unless you are refering to squaring the rear.
Pinion angle you have sounds good.
A neutral alignment (most cars are set up for road crown) is great for a drag car.
Sounds like you have good handle on things. Don't forget to make small changes at the track so you can see the effect and know what is working better and what isn't. A good place to start would be to adjust tire pressure a little bit each pass and see the effects. Of course, I'm just stating what I've learned from Madman and look what that guy did to my bumper
Hey Eric, if I want to get an alignment better for drag racing, what do I do, just go somewhere and say I want a neutral alignment? Are there specs I should give them that i'd find if I did a search? How can an alignment effect 60'?
Old Sep 9, 2005 | 06:13 AM
MADMAN's Avatar
LS1Tech Sponsor
Terry I like what you are doing. I wish everyone took as much time setting up their car.
Keep good notes of all your measurements and changes. Then change one thing at a time..
On the ride height issue of front to rear height I would rather see you lower the rear of the car to level it than raise the front. I know that isnt always possible but the higher you get the front the more air you trap underneath the car. This creates drag and also tries to pick up the car at speed which causes the car to move around.
Loudmouth get your car aligned by someone who has experience on cars BEFORE they came out with the computerized machines.
Tel them you want camber at 0, as much caster as you can get and then set toe. When you set toe make sure the car never toes out. Set toe at ride height, then raise the car till the front tires almost come off the ground and recheck, then pull the front end down like it is under hard braking. Reset toe. Make sure it is toed in some and never sees toeout.
__________________
www.madmanandcoracing.com
225-343-9029
Old Sep 9, 2005 | 07:41 AM
next's Avatar
What Madman said.
You see a guy with a plumb bob and string, then he's your man. There's two places in Orlando that I've gone and know what there doing for alignment. As far as the effect, less rolling resistance = faster.
Old Sep 9, 2005 | 08:31 AM
MADMAN's Avatar
LS1Tech Sponsor
The main thing a alignment will help is it will keep you from knocking down the wall at the track.
__________________
225-343-9029
Old Sep 9, 2005 | 08:32 AM
next's Avatar
And you told me it was so I could keep my eyes closed during the run
Old Sep 9, 2005 | 08:33 AM
HumpinSS's Avatar
subscribing
Old Sep 9, 2005 | 08:45 AM
MADMAN's Avatar
LS1Tech Sponsor
HumpinSS I looked at the videos you sent and they dont tell me much.
If you are going to video the car to see how it is working on the launch you need to be behind the car and off to one side. You need to look at the tires and the car. The front view doesnt tell alot.
__________________
225-343-9029
Old Sep 9, 2005 | 09:05 AM
383ss's Avatar
great thread, subscribing.
my best 60's have been when i can tweak the suspension to just lift the front tires. not a big wheels up, just squat and go.
I'll have to recheck my alignment and see if i can lower the car some.
Old Sep 9, 2005 | 09:19 AM
King James's Avatar
Subscribed
Old Sep 9, 2005 | 09:21 AM
HumpinSS's Avatar
Cool i will keep that in mind for the next time out at the track
Old Sep 9, 2005 | 09:47 AM
kevredz's Avatar
Originally Posted by Terry'sToy
adjust rear LCA's 2* uphill from rear to front of car, adjust diff side to side with panhard to centre diff. Use LCA's to get diff straight in the car, then last set-up pinion angle -2 to -3*.
What effect(s) does pinion angle have on the launch besides just pre-loading the rear end?
BTW, great thread.
Old Sep 9, 2005 | 09:48 AM
  #32
12secSS's Avatar
Try this for video taping. It really helps, I also try and get down low to see more of the suspension working. Get up as close as possible for better clarity.
And people ask me why I don't drive the car, too much data I need to see while the car goes down the track.
Old Sep 9, 2005 | 10:05 AM
  #33
Terry'sToy's Avatar
next, I would think the middle hole on the relocate brackets would be perfect for most people. The lowest hole might work if your car was lowered into the weeds. Thanks for the help.
Madman,
I'm keeping good notes on all of this, I keep a binder full of car info (like important threads and technical data) and every time slip.
I would have preferred to lower the rear of the car, but I raised the front because of the adjustable Hals. My other option was to cut the rear coils. I didn't want to do that at first. I would rather get adjustable rear springs (any suggestions).
I have the Spohn T/A, can I set it up like you set yours up. I'm not talking about the pinion angle here. I mean the angles of the bar itself and the forward attatchment point. I know the forward part of mine doesn't have the adjustability like yours, but I could make it that way. Cut,burn,weld
We always video tape like that. We even video other peoples cars and then show them in slow mo what is happening. They don't believe anything we suggest. You know how it is, you give some advice after you've been asked and then they think your a *****.
I on the other hand happen to listen to those who know what they are doing.
Thanks again for all your help.
PLEASE help me wreck my rear bumper.
Old Sep 9, 2005 | 10:12 AM
  #34
next's Avatar
Careful what you wish for! And get a set of SYA bars first.
Great shot George.
More ramblings on my suspension opinions - Here's my .02 on a common notion about wanting the rear to "squat". Those that subscribe to this think that the car should squat and that means the body of the car should go down. If that were the case, then the rear shocks/springs compress and that would mean that the tires would be going up away from the track. Not a good idea when you are trying to plant the rear tires. If you look at George's video you'll actually see the tires going down, not the body.
Old Sep 9, 2005 | 10:17 AM
  #35
Alright, cool, i'll try and find someone around here that can do that, thanks brian. By the way, I took the rear spring isolators out to bring the rear down some and try and level the car, and after doing that the lca angle changed and was only like 1 - 1.5 degrees upward from rearend to body, so I put them in the lowest hole, still gotta check and see what the angle is, but if it's over 3 should I put them back to the middle hole?
Old Sep 9, 2005 | 10:18 AM
  #36
Terry'sToy's Avatar
kevredz,
I think Madman is the BEST guy to answer this, but here goes.
First I don't really think pre-load is the correct term, as setting up the pinion angle doesn't actually put any load on the diff or pinion, at least not in the resting position. The idea is to get the pinion pointed downhill to keep the pinion angle lined up with the driveshaft angle under hard acceleration which helps the car bite better off the line. Under hard acceleration it also puts less load on the U-joints, as they won't be under any sort of angular load. The driveshaft and pinion will be on the same plane.
Old Sep 9, 2005 | 10:32 AM
  #37
Terry'sToy's Avatar
next,
This is primarily what I am talking about when I said to Madman about people not accepting GOOD advice.
"More ramblings on my suspension opinions - Here's my .02 on a common notion about wanting the rear to "squat". Those that subscribe to this think that the car should squat and that means the body of the car should go down. If that were the case, then the rear shocks/springs compress and that would mean that the tires would be going up away from the track. Not a good idea when you are trying to plant the rear tires. If you look at George's video you'll actually see the tires going down, not the body."
Loudmouth,
I would try the 1-1.5* hole and do a couple passes, then try the other hole. I would suspect the 1-1.5 would be better, but I'm not sure just yet.
Old Sep 9, 2005 | 10:36 AM
  #38
next,
Loudmouth,
I'm not gonna be making passes for a little while, I put the car down, gettin the money together to upgrade my safety stuff and gonna pick up a madman t/a to try and help her to hook. Also gotta get new slicks.
Hey Brian, you recommended the 28x10.5S instead of the regular one's, right?
Old Sep 9, 2005 | 10:43 AM
  #39
Terry'sToy's Avatar
Loudmouth,
did you measure the angle with your body weight in the car? When you sit in the car that will reduce the angle. So if you measured the car without weight in it, I would re-measure.
Old Sep 9, 2005 | 10:45 AM
  #40
kevredz's Avatar
kevredz,
Thanks for the reply.
So basically, having negative pinion angle in excess of what you need to obtain 0 degrees under hard acceleration is unnecessary?
