Drag Racing Tech
Looking for tips on hooking my 73 camaro.
Old Sep 12, 2005 | 04:25 AM
camrsz's Avatar
Default Looking for tips on hooking my 73 camaro.
The car. 73 camaro ,ls1, t56, 200 shot dp nitrous
the car is gutted with a 6 point cage. 3000 pounds
8.5 rear 4:11 gear. aftermarket leaf springs(softer)
Im wondering if anybody has experience making a leaf spring car hook up.What shocks, traction device. slicks did you use
I plan on 4 linking the rear with a 12 bolt this winter, but I want it to hook the few times I get it out yet this year.
Thanks
Old Sep 12, 2005 | 09:49 PM
CTSmechanic's Avatar
Cal Tracs..... check over on Nastyz28.com theres a few people running there with great results there about 330 bucks a set and are used on tons of cars that run well into the 8's or you can check out Calvert Racing.com
Old Sep 12, 2005 | 11:37 PM
Sandmann120's Avatar
I'll second the Caltracs. Very nice setup. Also a set of adjustable shocks. You can fit a lot of rubber in a second gen wheel well.
Old Sep 13, 2005 | 03:46 AM
terr1bleone's Avatar
i say caltracks too, but what did you gut to get it down to 3000lbs? pm me if you can mines a pig right now.
Old Sep 13, 2005 | 06:59 AM
camrsz's Avatar
Thanks for the help.
as far as gutting it.. all of the factory wire harness is gone. all interior except headliner and some plastic panels. aluminum race seat. No inner fenders on the front. fiberglass hood. Fuel cell. I lost alot by switching to rack and pinion steering. no powersteering. The ls1 helps alot as well. Thats all I can think of right now.
Old Sep 13, 2005 | 07:19 AM
HotRod68Camaro's Avatar
yep CalTracs. Iv got them on my 68 and saw an incredible improvement. And of course drag springs in front, qa1 makes some sigle adustables, but id say since your goin w/ a 4 link theres no reason to fork over the cash for the qa1.
Old Sep 13, 2005 | 11:29 AM
Villain281H's Avatar
7 Second Club
From: Gainesville, Florida # of drag strips runs: ?!?!?
I'm currently running Competition Engineering shocks (90/10 front, 50/50 rear), Competition Engineering traction bars, Moroso trick springs and Landrum leaf springs on my Nova, and have seen a best of 1.498 60 foot on a 9 inch wide M/T ET Street, but I'm swapping to a set of Cal-tracs next year. They work great, and John is a great guy for support.
Good luck!
Derek
Old Sep 14, 2005 | 10:20 PM
camrsz's Avatar
Are caltracs better then the comp engineering slide a link bars?
Will the drag springs up front raise or lower the front end? I have the engine set back about 6 inches so there is not much weight over the front springs.
Old Sep 14, 2005 | 10:27 PM
LS1SSII's Avatar
Go with Cal-Tracs and Rancho Shocks. They make a nine way adjustable that is far cheaper then any adjustable shock out there. This is what Cal-Tracs recommended to me and it works great. My car 1.44 60 ft's on a 10.5" slick.
They will be able to cross reference a shock for your car.
Old Sep 14, 2005 | 10:33 PM
Yea id say go with what the guys at Cal-Trac recommend. as for the comp engineering bars im sure they work well but no clue compared to the Cal-Tracs.
Old Sep 14, 2005 | 11:56 PM
camrsz's Avatar
Any ideas on the front springs?
Old Sep 15, 2005 | 01:24 AM
This is what i would for your car.
go all out on the front suspension now:
Option 1)Qa1 Coilover conversion
Global West Suspension Components Tubular upper control arms
Option 2)Moroso Drag Springs and some single adjustable socks
For the rear all you need are some Traction bars and depending on how much you want to spend right now (since you'll be spending more later on the 4 link) either:
Option 1)A single (12 way) adjustable sock
Option 2)three-way adjustable shocks
Old Sep 15, 2005 | 07:27 AM
7 Second Club
In my opinion, yes the caltracs are better than the slide-a-links. Not bashing slide-a-links as they are a nice step-up from traction bars.
Drag springs will raise the front end up in the beginning, but will settle after 3-4 weeks of driving/racing. They are sold based on front end weight, even with your engine setback you'll be ordering for the actual front end weight and model of car, not just model. I had to cut 1 full coil out of my moroso springs to get the height I wanted, and I have about 5-1/2 inches of travel before the wheels come up.
Derek
Old Sep 15, 2005 | 10:16 AM
camrsz's Avatar
Derek
Thanks thats what I wanted to know
Old Sep 15, 2005 | 10:19 AM
camrsz's Avatar
I will end up with coilovers in the front someday... But dont think I could afford them now with how much im putting in to the car to get it driveable. thanks for your ideas
Old Sep 15, 2005 | 10:22 AM
marine02ss's Avatar
Go with Cal Tracs and Qa1 adjustables!!
Old Sep 15, 2005 | 10:47 AM
camrsz's Avatar
Is calvert racing the the only place to by them through. The clatracs that is.
Old Sep 15, 2005 | 12:12 PM
Ls1LikeNoOther's Avatar
Comp eng 3 way adjustables on all 4s,you cant beat em for the money..Put cal tracs on the leaf springs and leaf the stock springs in...Should have a pretty nice lil suspension then..
Old Oct 29, 2005 | 12:58 AM
nick_s's Avatar
so after all this discussion are you still going to waste $ on a 4 link?
Old Oct 30, 2005 | 09:21 AM
Terry'sToy's Avatar
We run cal-tracs on drag race monoleafs. (You may want to talk to Calvert racing about this also, as they suggested mono leafs to us.) We run Moroso drag springs on the front and also had to cut a coil. This is in a 75 Nova 427 BBC T-400w/brake 4500 stall and 4.56 spool 8.5 10 bolt. It runs 1.46 60's and pulls both front tires a foot up.
I wouldn't waste a dime on 4-link, unless you know someone who can actually set it up correctly for you. The cal-tracs are dead easy and in my opinion better than the slide-a-link (as we have them on a 74 nova)
