Drag Racing Tech
wheels up down up down!!!
Old Sep 16, 2005 | 04:54 PM
ou812/z28's Avatar
Default wheels up down up down!!!
my 60,s are always from one extreme to another and yesterday while watching some old footage i think i see why.while i was watching i put it frame to frame slo mo and you could see,. it will leave with the front in the air about a foot off the ground for about 10 feet and then down ,then back up for about 5 feet... what is going on and why,how do i stop this bc i know it is not good for et,,,,,
Old Sep 16, 2005 | 11:30 PM
Wnts2Go10O's Avatar
u need a smidgen less weight transfer. whats happenin is just about all the weight is getting put over the rear and yea...lift off.. jus tune the suspension a lil bit and ull be fine.
Old Sep 19, 2005 | 05:18 PM
Terry'sToy's Avatar
I'd say it's probably shock tuning.
Try tightening the front shocks up.
Old Sep 20, 2005 | 10:29 AM
ou812/z28's Avatar
this weekend when i go i will dothat and let ya;ll know...thanks/
Old Sep 20, 2005 | 11:07 AM
MADMAN's Avatar
LS1Tech Sponsor
You are loading the tires then this is causing the motor to bog. This unloads the tire which then allows the tire to spin which starts the sequence over.
I would air the tire up in the rear.
__________________
www.madmanandcoracing.com
225-343-9029
Old Sep 20, 2005 | 11:26 AM
Terry'sToy's Avatar
Madman,
We were having this discussion at the track on Sunday, we were wondering how do you decide if you need a higher shock setting or more tire pressure, I'm confused.
I didn't intend to hi-jack your thread, I just thought it would be helpful.
Old Sep 20, 2005 | 11:31 AM
MADMAN's Avatar
LS1Tech Sponsor
A higher shock setting will hit the tire harder. If you want to kill the bite then add air and loosen the shock. More hit then tighten the shock.
__________________
225-343-9029
Old Sep 20, 2005 | 11:38 AM
Terry'sToy's Avatar
I understand adding air to kill bite, but I don't understand how loosening the shock kills bite. I thought a looser shock would let the diff push into the ground faster. Or is it that the looser shock lets the body rise too fast in the rear?
Old Sep 20, 2005 | 01:21 PM
MADMAN's Avatar
LS1Tech Sponsor
The stiffer the shock the harder it plants the tire. Unfortuneatly the single adjustables arent the best for chassis tuning.
__________________
225-343-9029
Old Sep 20, 2005 | 01:27 PM
CAT3's Avatar
Restricted User
Are there any other shocks out that are comparable to the Afco's, like a HAL maybe? Same issue I will be dealing soon enough. Love the QA1's for a dual purpose car, but like to lean more towards track and more sacrifice on street
Old Sep 20, 2005 | 01:54 PM
Terry'sToy's Avatar
Thanks, I got it.
