Drag Racing Tech
What does it take to pull the wheels up
Old Sep 21, 2005 | 03:48 PM
4thGenTA's Avatar
Default What does it take to pull the wheels up
Not sure if this is the right area to post but oh well. I was wondering if I put a 12 bolt or 9" in with a 200 shot on an all stock motor with upgraded fuel system. Plus stage 2 clutch if I could pull the wheels up and i mean really pull them up not just twist the car so one wheel pulls up.
Old Sep 21, 2005 | 03:51 PM
DONAIMIAN's Avatar
either a light weight stock car with traction, or a full weight cam only car. It has been done in 6 speeds many times on a stock rear, but how long will it last is the question. BTW pulling the wheels is for nothing but bragging right, it slows you down.
Old Sep 21, 2005 | 03:56 PM
02 Camaro SS's Avatar
With a REALLY good suspension it can be done with just bolt ons. ~400 rwhp or more seems to be enough to pull them up on a lot of f-bodies.
Old Sep 21, 2005 | 04:02 PM
4thGenTA's Avatar
I know it slows you down i would like to just be able to do it to show up all my FWD import friends. But do you usually have to leave at like 6000 or can you do it at like 3000
Old Sep 21, 2005 | 04:36 PM
magius231's Avatar
you need to leave at a pretty hefty RPM to pull the wheels up, I wouldn't count on the stage 2 clutch lasting real long doing that though. Slicks or a really good suspension with DOT drag tires and apparently around 400rwhp. Pull up the wheels and watch **** on your car break
Old Sep 21, 2005 | 04:52 PM
MAXIMO's Avatar
Yeah really that is just for bragging rights. I saw a car pull the wheels and still ran a 9 sec pass. Red ta its on the net alot. Still you might wanna lighten the font end. Like relocating battery, bmr kmember A arms. and some light shocks and springs. There was on package that I saw I think with the K member a arms and springs and shocks I think It removes almost 100 lbs from the front end. Ill go search for the links. Ill post them laters.
Old Sep 21, 2005 | 04:53 PM
gollum's Avatar
"A high grip rubber grooved racetrack helps the most".
Along with bigger drag DOT tires or slicks, strong rear end, strong clutch, 90/10 adjustable front shocks with front sway bar removed, skinnies, air bags in rear coil springs or adjustable rear shocks, and a higher RPM launch.
Old Sep 21, 2005 | 05:58 PM
magius231's Avatar
oh, if you just want bragging rights, put about 600lbs in the back of the trunk and then do it. You could get a semi to wheelstand with enough weight past the rear tires.
Old Sep 21, 2005 | 07:53 PM
TAF Motorsports's Avatar
Default pop a wheelee
Mods we need a "how to do car tricks" section
Press the gas really realy hard.... and jerk the steering wheel back really hard!!
sorry i couldnt resists
Old Sep 21, 2005 | 08:12 PM
dug's Avatar
dug
It dont take much power to do a wheelie. My bro's 5.0 Mustang would yank them good with 28x10 slicks, 4.10 gears and 6k rpm launch. Car only ran mid 12's at 110.
I think a stiff chassis helps lift the car instead of twisting it.
Old Sep 21, 2005 | 09:23 PM
nuzee's Avatar
It took a low 1.6 60 ft. for me. Just the front swaybar removed.
Old Sep 21, 2005 | 10:21 PM
Terry'sToy's Avatar
That'll work, just get some real slicks. Suspension stuff also helps. My car lifts with a 1.62 60'
Old Sep 21, 2005 | 10:23 PM
4thGenTA's Avatar
ANother question. Are tubular sfc strong enough to pull wheels up or will i still damage my car with them.
Old Sep 21, 2005 | 11:33 PM
chpmnsws6's Avatar
it is enough for awhile but if you continue without a set of bars in the car, it'll twist
Old Sep 22, 2005 | 04:10 AM
jaberwaki's Avatar
wheelies are ok, but low 60's are better
Old Sep 22, 2005 | 04:29 AM
waterbug1999's Avatar
I tried that.. And it does not work.. lol That was a good one bro!
Old Sep 22, 2005 | 11:52 AM
Bitemark46's Avatar
Suspension has alot more to do with pulling tires than hp does. It doesn't take alot of power to do it. With skinnies up front and loose suspension a stock longblock ls1 can do it. Of course a sticky tire is mandatory for it. FWIW, even though it's a mustang, I was able to pull the left front on a 17" nitto DR with only a 1.74 60' with 300rwhp. But my suspension is setup for major weight transfer. But it is fun as hell to pull a tire or tires. -Mark
Old Sep 22, 2005 | 12:48 PM
Bryan @ Speed Inc.'s Avatar
i cut a 1.62 60' and only got only the one wheel off the ground..... granted i'm running a full weight car w/ stock 16" front wheels and tires. torque arm, lca's and front sway bar removed. 28" tall m.t. d.r.'s
the cool thing is that i carried it past the tree
Old Sep 22, 2005 | 01:56 PM
transam1998's Avatar
How is this going to impress the fwd crowd? If they were to pull the front tires up, they would lose their power to the road.
Old Sep 22, 2005 | 02:10 PM
Black8Banger's Avatar
so what impresses a fwd crowd? pulling the rear wheels?
ok yea i know that was dumb...disregard that
