Drag Racing Tech
Spring options with Hal QA1 - R's
Old Sep 22, 2005 | 11:05 AM
2001 Pewter WS6's Avatar
Restricted User
Default Spring options with Hal QA1 - R's
I have an Iron 408 and think the Hal springs are too soft. I have BMR lowering spring on it now and was thinking about using them with modified perches on a set of QA1 R's. How do you feel this would work. I street drive the car as well as race it. Any input would be appreciated.
Old Sep 22, 2005 | 12:52 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
When I had my old 422ci iron block and Hal front springs and shocks, the car was too low. And the airdam would scrape a lot.
You can run lowering springs just make sure the car is not too low in front. If it is put stock springs back in the front.
Old Sep 22, 2005 | 02:20 PM
Restricted User
That is probably my best to put stockers back in.
Old Sep 22, 2005 | 02:28 PM
Bryan @ Speed Inc.'s Avatar
did you get that thing into the 10's yet???
Old Sep 22, 2005 | 08:24 PM
Restricted User
It ran 11.17@123 in street trim with th efull interior and with 17's on it and then the rear end let go. That was with a 3000' DA. I am putting a 12 bolt in tomorrow and should have new times next week and hopefully it will be a little cooler.
Old Sep 26, 2005 | 12:06 PM
z-ya's Avatar
Qa1 also makes 300 and 325 lb springs if the 275's are to soft.
Old Sep 26, 2005 | 01:35 PM
onfire's Avatar
Coal Mining Director
My stock springs were 294lbs. I went with the 325 springs since I added 85lbs of turbo weight.
Old Sep 26, 2005 | 01:39 PM
and you're going w/ 4.10 gears... oh baby this thing's gonna fly. let us know how you do!
Old Sep 27, 2005 | 11:39 AM
Restricted User
I probably added around the same weight with my iron block. I will look into those.
Old Sep 27, 2005 | 11:41 AM
Restricted User
Well the rear is in and the slicks are on. I am just hoping the weather holds. It is supposed to be 65* for a high and an over night low of 40* so it should be pretty nice at night as long as it doesn't rain. Our track is 1250' so that doesn't help the 'DA.
