Need alignment and other specs
I'm taking the car to the local alignment/ performance shop tomorrow, and I need some specs to tell them. The car rides on big n' little 90% of the time, and the rest of the time its on 17" ZR1 rims. I have the QA1 adjustable shocks all around with the coil overs up front. I dropped the front and rear about 1.5" or so, and I'm pretty satisfied with the ride height. I might go up or down maybe 1/2", but nothing major. This is primarily a street car that sees a few track visits a year. I need to set my pinion angle, which I think needs to be about -2 degrees, and have my front end aligned. I'm also going to have them check to make sure everything is square ar far as my adjustable LCA's and panhard rod. I also have a random tech adjustable TA. My rear ride height is staying for now, but might have to go back up a little if the car won't hook on these springs. I'd say the most the rear will move is 1" in either direction. I liked the factory springs but they sat too high.
I need some specs for the front end alignment and opinions on the pinion angle. Plus any other info that might be useful. Thanks!
